My MF7 is a 1970, and it has the zirks.This year is this tractor's 50th birthday, Chris. The MF8E has it's 60th birthday this year. The 8E has the zirks. Somewhere in that 10 year span they cheaped out!
Ok, somewhere between '70 and '75 they dropped the zirks! Thanks, Nick!My MF7 is a 1970, and it has the zirks.
Looks like it would work real well, Chris, but this animal has to be 9" long. Would take quite a bit of fabricating to build that.As far as the Lovejoy goes you could put a sprocket on each shaft and wrap a chain around them. This allows for a little movement but keeps things aligned.
Holy crap, a buck a piece for grease zirks? Dang! Post a pic of what those drive in ones look like if you get a chance, Daniel.All the talk about drive on grease zerks caused me to order 10 in 3/16" and ten in 1/4". $1 each! Didn't fine an assortment box, but even if I did, it would be cost prohibitive!!
Making good progress, DAC.Please read the above post too!
Did a test fit and looks like it might work.
Cleaned everything up with brake cleaner and used Gorilla epoxy to attach the plate to the butchered up base. Put a weight on it and anti seize on the bolt to align it. Didn't want to epoxy that bolt in! That old surface wasn't flat enough to just lay it on there, and it needs to stay put anyway.
Going to pull the carb and clean it, take out the spark plug and see if I can stick the bore scope in the hole to assess the damage to the engine. It was running fine last time it was used last fall.
Will leave that epoxy set overnight. Don't know how much I can get done tomorrow. Have to go to Sam's club and I have a doctor appointment too.
Steering u-joints aren't rated to spin 3,000 rpm plus. I'm sure there are high speed smaller u-joints out there, but that's one more thing to buy, then the splined couplers and invent flanges to make it multi piece for installation. Think I'm better off dealing with this setup. Just going to have to line up the shafts fairly precisely. Still on the fence about spending 150-200 bucks for a couple of 11 spine couplers. What I took off was still working and the shafts on the tractor don't look any worse.Would a small steering U-joint work to replace the Lovejoy?
One would think that barbed fittings like that aren't much cheaper, actually they seem a lot more expensive, but the cost saving must be threading what they will get driven into. Pretty dumb idea in my opinion. Some engineer needs to be tarred and feathered---LOL!Here's pics of drive in grease fittings. 1/4" on left, 3/16 on right. You drill exactly that size hole and the ribs are oversized to drive in tight. I seldom need these thankfully due to their high costs. With KY sales tax, EACH one is $1.06!
Old sockets can come in handy many times Daniel. I have plenty of assortments just to bang and press on.The tool to drive them in is around $14, but I've always just used a socket that just slides over the fittings grease tip. The socket hits on the base, so it doesn't bang up the tip.
Thanks for the comment, Rog! Yes a PTO u joint should work fine. I should have thought about that more. Automotive steering column u-joints wouldn't hold up. I have used lots of them on racecars through the years. They aren't built to handle rpms. We used to get them out of junked Toronados and a couple others I don't remember anymore.Using a small u joint will handle the speed. They use them on PTO equipment a lot. I put one between a B&S 18 hp and the hydro that was a close line up and it ran for 2 years before I sold it. Did not spline either shaft either. Just ground a flat for the set screw to lock down onto the shaft.
I've built several tools out of old sockets too. 2 I can think of are a rear brake caliper adjuster for a 2011 Dodge Journey we had. The piston screwed out rather than just pushing out like a normal one. Glad Loree traded that thing off for the '06 Denali I drive now. Took a special socket to screw the caliper piston back in. Then I built a upper balljoint adjusting socket for a Dana 44 front 4x4 differential. Was too cheap to go buy the tools.Old sockets can come in handy many times Daniel. I have plenty of assortments just to bang and press on.
I only have cheap ones, Jim. No brand name. Just says "China" on them---LOL! I just go very slow and lots of cutting fluid. I think they came out of the scrap trailer at work too!Good fix on the filter base Doug. I need a good set of metal hole saw cutters. I’m tired of buying the cheapies. I’ve used some of the Bi-Metal cutters but still not too good.
This thing has run rich since day 1, Aaron. You got me thinking about carburation. I fought it for awhile and then gave up. I just don't let it idle much. I think I went to a .035 jet from the factory .040 At that time I couldn't find any smaller. Our altitude is about 3700 FT.Crazy to see a predator running rich. They usually jet them so lean from the factory for “emissions”. A cone filter and exhaust on a 6.5 requires going up 3 to 4 jet sizes right off the rip to get it close, 1 size up on the pilot to help off idle throttle response and a different e-tube.
I like your air filter setup! I cant remember exactly what we did on the MF7. I know it required butchering the factory air box!
