NO AC, windows open, and no hearing aids needed!!!Windows up, AC on high, hearing aids turned off. Sounds like something I would do.![]()
That's the hard part right now!It sounds like the Van Sickle paint formula is designed for slower drying so the Naptha will be slowed a bit because of that. If you don't have it painted yet, hope you get a day below 90F like they recommend!
Have you found ospho to make a big difference on metal used in the weather?Today, I wire wheeled the welds & rusty areas then gave it coat of Ospho since I have no idea when I'll paint it.
View attachment 27481 View attachment 27482
For those unfamiliar with Ospho, check this.
Never used it before. Going on a recommendation from someone who has.Have you found ospho to make a big difference on metal used in the weather?
For $26 a gallon at ACE hardware, worth trying!Maybe I should tell you what he told me. The Ospho creates a barrier between the paint and metal. The paint adheres well to that barrier and keeps new rust from forming.
Took less than a quart for the trailer brushing it on.For $26 a gallon at ACE hardware, worth trying!
I'm inside or in the shade. Even nasty in the shade as the winds are close to nil.Dang that's HOT! Take it easy Kenny!
The sooner you paint the cleaner and less weathered the ospho will be. I would paint as soon as posible.Today, I wire wheeled the welds & rusty areas then gave it coat of Ospho since I have no idea when I'll paint it.
Yes we want to see a showroom finish on this wagon. Ospho handy. I wipe it on rusty metal ahead of painting. Just applied some to this head rack I’m alteringMay be a while yet, Don. I'm not that good with HVLP guns as yet!
I planned to get a Tyvek suit to wear. Main part is it's going to be up to the horizontal.You should have no problem spraying horizontal. I have always painted floor of pickup box. You will be adjusting your spray nozzle for the 4" channel to a narrower pattern. You can spray any direction, I painted underside of floor of project car I'd sandblasted. You'll have to be properly covered up when painting floor as the paint tends to bounce back depending on the pressure your gun requires to decently atomize the paint. You could always jack up side of trailer to make spraying easier,... take your time. I'm sure you have read the instructions on your spray gun![]()
