OH How HappyDid this band have any big hits, that I might know, because of my age. Hehe.
I remember years ago building cabinets you could finish sand cabinet grade plywood for awhile to get a good surface for painting or staining. Now days the veneer is so thin you can’t do that.Staining new doors for the house, replacing all the interior doors with Knotty alder. Have 2 coats on 4 of them, 1 coat so far on the other 2. Once everything is all caught up with 2 coats (had to put a 3rd coat of stain on 1 side of each of 2 of them to even out the color, these still had white blotches that made them look weathered) then I gotta start laying poly onto them. At least 2 coats. I only have 4 sets of sawhorses, and a pair of upside down garbage cans so I have more staining and varnishing to do, than stuff to set the pieces on to work at the same time.
Some of the new doors were just slabs and some came pre hung with new jambs. Veneered no less. Damn OSB just splintered when I took 2 of the 3 jambs apart to stain e. Looking for some alder 1 by 6s to make my own new jambs out of, I'd rather have real, (solid) wood for these doors to hang from. And ordering them that way would be 6 weeks or more of waiting, and more than double the cost of a pre hung.
Don't make sense veneered product would be cheaper, considering how much more work to veneer something vs just cutting them out of real wood in the 1st place
My Simplicity 3415H isn’t charging the gen light stays on. The battery voltage doesn’t go up with high throttle. The starter generator is good so I took the voltage regulator off to clean the contacts. I put the VR back on and flashed it. I started it back up and still not charging. I guess I’ll be shopping for a new VR. Any suggestions on what brand is good. I’m sure most are from China.
Maybe this will help:My Simplicity 3415H isn’t charging the gen light stays on. The battery voltage doesn’t go up with high throttle. The starter generator is good so I took the voltage regulator off to clean the contacts. I put the VR back on and flashed it. I started it back up and still not charging. I guess I’ll be shopping for a new VR. Any suggestions on what brand is good. I’m sure most are from China.
Thanks Kenny I have that downloaded on my desktop and was going to look at that today. Like Lance mentioned it’s been awhile since I’ve had one of these opened. I priced some last night the Delco Remy is about $80.+shipping and the China brands are about half that. If I can’t get this one adjusted I have a friend up the road might have a used one. I’ll probably be replacing the China brand again next yearMaybe this will help:
Same here Lance they do adjust but I’ll have to re educate myself on these.Maybe an adjustment in those. Might make it work. Been a while since I had one of those apart.
It’s a lot more difficult to achieve a random pattern than it should be.Flooring is time consuming...
I have done a lot of flooring over the years mostly by myself. It’s good to have a helper with a good eye for pattern to lay it down ahead of you but for me that hardly ever happened. In my later years being by myself was a good thing because I can only nail off a smaller area before having to straighten up and rest a moment.It’s a lot more difficult to achieve a random pattern than it should be.
