You have the ground clearance to it sounds like it it going to work well! Glad you don't have to cut up such a solid body!Trying to avoid both of those. The motor clears the fire wall but the tranny presents a problem. Almost all of the pics I have seen show a flat floorboard Which is what is was originally so I am trying to keep that by setting the motor lower in the frame. Ground clearance should not be a problem. My Ford Edge only has 7 inches of clearance, I will have around nine on this.
