Yep, .100" per pass, goes quick!Aluminum is fun to turn!
Looks like it belongs in there, glad it fits! You do good work measuring and drawing, made my part easy.I got the adapter/spacer in today. But the tractor didn't want to start again. May be time to rewire this sucker and get rid of that stupid box!
I ran a wire to the coil from the battery and it still wouldn't fire off. I may have to get another switch as it seems to fire just as I let off the starter.Kenny
To check the switch put a test light on out bound side of switch and crank it over and see if the
light goes out when cranking check all out bound connections. Or you could try a wire from battery to brain box. hope this helps
thanks Bill
I put that on the to do list, Brian. Not gonna be warm enough here to be outside for a week!Kenny, check the safety switch circut again to make sure it completing the could circut.
It is an Onan, but no points! I'll run a hot wire to the coil, it's just not shown. But that would verify it's all in the original wiring. No time today to work on it. Gotta get ready for the bad weather for the weekend.Kenny
You could run a wire from battery to a switch but you will need two wires going from the switch one for ignition and one for starter Solenoid. per your diagram you have only hot wire coming to switch& and a wire going to solenoid but you will need a wire going to coil. You do have points on engine and is a Onan? I am in fl for the winter but have a onan manual for my generator. I had a problem it a briggs and it was spark plug looked good when i put new spark plug problem solved.
good luck.
bill
I see you have winter stuff coming in Kenny. We're having some come in too, but not much, or so they seem to think.It is an Onan, but no points! I'll run a hot wire to the coil, it's just not shown. But that would verify it's all in the original wiring. No time today to work on it. Gotta get ready for the bad weather for the weekend.
Yeah, Daniel! They can't make up their minds about what we'll get. Hope it's not ice! Been doing some 'winterize' things today. Got the wind break on the front porch and took the canopy cover off. Might get to play with the 316 some.I see you have winter stuff coming in Kenny. We're having some come in too, but not much, or so they seem to think.
