Hi folks,
I got somewhat of an update on the tractor, and there is story behind this one. I took the seat off the tractor a month ago to work on the voltage regulator and the battery box and just left it off to eventually sand it down, primer it, paint it, and have it reupholstered. I thought to myself a couple weeks ago when it was a very warm temperature and sunny day out that "today is gonna be that day", OR so I thought. I was taking the nuts and bolts out of the seat with a ratchet and socket to sand it down with my stepdads DA or dual action sander/polisher, and my stepdad says to "just grind them off it will be faster" so we did. When we grinded the nuts and bolts off the seat we noticed that the crack in the middle of the seat just so happens to be so to speak "bondoed" or patched with brass, I say it is bondoed or patched with brass because we took the grinder and put the wheel on and it did not create any sparks. See 1st photo below.
Anyway as a separate note if you look at my 2nd picture, when we grinded the nuts and bolts off the seat there was a non original plate that the nuts and bolts were holding onto. I say the plate is not original to the seat because I looked at the bottom of my 10 horsepower Craftsman seat and it is different like in the 3rd picture, and just to verify if it is like the 3rd picture I looked at my stepdads 10 horsepower Craftsman and it was the same thing. That said right now the plan of action is to......
1) Sandblast the whole seat from the tractor,
2) Have the local fabrication shop I had make my battery box pieces fix the seat and make the correct piece for the bottom,
3) primer, then paint the seat black,
4) then have it reupholstered in the same pattern as my 10 horsepower seat.
Wish me luck!
What the bottom of my seat
SHOULD be, (photo courtesy of a seller on Ebay 2022)......
![s-l500.jpg s-l500.jpg](https://tractorfanatics.com/data/attachments/53/53196-6f790253bd76a150856777cbd6421e64.jpg)
