Good information, Aaron! Thanks!I think a 2x4x8 would support 300lbs. That’s at 8 feet. I’m sure at 3’ it would support much more.
If you feel uncomfortable with it double up your 2x4s.Good information, Aaron! Thanks!
Hopefully this link is correct. There are also two ton unites available that are cheaper.Do you have a link where you got the jack, could use that when setting up my camper.
Probably the weakest point it where the end of the 3' 2x4's are fastened to the cross pieces. Metal hangers would take care of that easy enough, if you didn't already use them.
The only ones that should need a joist hanger is the center one in each section. I do have some 2x4 hangers around here but I haven't seen them since 2018 when I hung the new furnace---LOL! I'll look tomorrow. The 2x4s on each end are load bearing. and the outer lengthwise ones also lay on the lip of the lift.Nice job Doug I agree with Roger I would add joist hangers. Your board spans are good but screws snap under pressure because they don’t flex, nails will flex and allow the joint to release. I would paint it to match your lift too lol…you have to make it perdy.
I wonder if i could adapt that to my motorcycle lift?Hopefully this link is correct. There are also two ton unites available that are cheaper.
Doug, do you think one of those would lift a car high enough off the ground to set a jack stand under it?Hopefully this link is correct. There are also two ton unites available that are cheaper.
VEVOR Electric Car Jack Floor Jack 3 Ton Electric Scissor Jack Car Repair Tool 644097101051 | eBay
Find many great new & used options and get the best deals for VEVOR Electric Car Jack Floor Jack 3 Ton Electric Scissor Jack Car Repair Tool at the best online prices at eBay! Free shipping for many products!www.ebay.com
Possible I suppose, Rick, but if your lift has a hydraulic cylinder, you can buy small electric pumps for them. Problem Is I've never bought one. My brother-in-law has all kind of gadgets in his shop that used to be manual pump converted to electric pump.I wonder if i could adapt that to my motorcycle lift?
Would sure be better than the foot operated pump on there now.
I couldn't really say for sure, John. It has a little over 13" of lift. Probably would have to lift on an axle or suspension control arm. There is a head to screw into it that extends it up a few more inches. The stuff I'm going to use them for, will have that jack beam on so I'm thinking it will work for my needs.Doug, do you think one of those would lift a car high enough off the ground to set a jack stand under it?
jhn9840
John
Thanks Noel! Had some progress today.Looking good Doug.
