Too late. the parts are ordered, Noel. I did pay 7 bucks extra for a "buyer protection policy" for whatever good that might do.I would look at the wiring real close to make sure it’s ok Doug. Then I would put power to each fan motor to check those. Check the voltage required to do that. Heat fan should be 120AC, not sure about the combustion fan. Could be 24 AC or 120 AC. Can’t remember. Been a while since I worked on one. But, be good to make sure before putting new parts on. No returns on electrical stuff. Around here any way
I can inspect the wiring. I already did somewhat, but will give it a closer look. Far as powering up the fans, not sure on the voltage yet. I don't have a power supply that can put out 24VAC though. Jump it from the transformer I suppose? Didn't get to check them out further today.I would still check it Doug before you put the new parts on, so you don’t ruin the new parts possibly. Just a thought.
Highly doubt the fan motor is 24v. Looks like a pretty small transformer to be powering much. Possible I suppose.I can inspect the wiring. I already did somewhat, but will give it a closer look. Far as powering up the fans, not sure on the voltage yet. I don't have a power supply that can put out 24VAC though. Jump it from the transformer I suppose? Didn't get to check them out further today.
Thanks for the advice, Noel!
Yeah, on the circuit board as stated earlier, Bill. Looks like you're right about them being 120V. Will try to get them tested.Highly doubt the fan motor is 24v. Looks like a pretty small transformer to be powering much. Possible I suppose.
Is the fuse you're blowing on the circuit board ?
Thanks Noel. I should have read this stuff sooner. The fans spin freely is all I know right now. Never had a chance to get up on the ladder today.
It said one left, when I ordered it, Daniel. I think the kit for the 50 and 75,000 BTU furnaces are the same though. Component part numbers are the same including the mother board.That kit now shows as out of stock. Good you ordered when you did!
I can walk standing straight up with a hat on with plenty of clearance, 79", Chris. With a truck on it the lift will be lower. Ceiling height is 13' 8". I figured on rolling around on a chair most of the time while working on the underside of a truck.I like the way those lights turned out. Nice place to work under there if you don't hit your head.
I ordered 20 of those hooks from an epay store, Jim. $13.29.Nicely done Doug it worked out great. I like those magnetic hooks I’ll have to get some of those. I’ve seen them but for some reason I’ve always related them to an office not my shop.
I can probably get a truck on the lift and stoop a little walking around under it, but this arthritis in my back don't like to stoop. standing straight up is ok or sitting. Lot of pain in between the two. Then the overhead door reduces the ceiling height to about 12' when the door is open. Also, a ceiling fan in the way, but I suppose it should come down. I will try to get some measurements soon.Just wondering Doug. Why would the truck be lower and you going to use a chair to work on it. Personal choice ? Or won’t go high enough for you to get under.
Sons ceiling is 13’ and a little. He has no trouble putting a truck on the hoist and workin on it.
Maybe I’m not understanding correctly. Ive been known to be like that. Hehe.
It will be close. Just need to put a truck on it and see!Glad ya got you heat back on for the summer. Hehe.
So if the fan was gone and door down you can get it up high enough if you wanted.
