Nice looking decal Doug.
Not a decal yet, Noel. Just designed. I'll get to that later.
Noel what the heck are you doing up this time of day?
He does that all the time!
That tail looks professionally done. My wife has a Cricket (sp?) and is pretty good with it but not nearly up to your standards.
I was in the sign business for over 30 years, Chris. It was my job to make logos and good layouts look professional. Think it is spelled Cricut. They are pretty capable little machines!
God job Doug nice idea with the MF design. My shop clock went bad awhile back and I’ve been wanting to make a clock using a B&S engine shroud with the clock face in the stator hole. I like the ideas of using the tractor colors and decals on unusual items.
I've got so many clocks around here, I don't even know which ones might work and which don't. Someone ought to "clock" me upside the head---LOL!
Exactly the reason I was up at 3:30am. Not my favorite happening
Dang Chris, I get up to pee about that time! Go back to sleep ok. Sometimes a couple of tylenol then too. Laying in bed is about the only time I don't hurt too much.
hehe. Well. Some nites I just can’t sleep. So I drink coffee. Hehe. Then after a while I go back to sleep. Hehe.
If you can go back to sleep after drinking coffee, I think you are using decaf with a big shot of whiskey in it, Noel!
Didn't get to cut those stickers yet. Woke up to no water this morning. I was hoping the infra red heat lamp in the well house burned out. It usually freezes the pressure switch first fooling the pump into thinking that the tank is pressurized. It is on a thermostat set to turn it on at 38F. That is what happened. Loree called me after I got the bulb replaced and said that she thought the water pressure was too low this morning when she went to work. Told her she was right. What else would you tell a woman anyway---LOL! Just after we got done talking, the water came back just fine. Took about an hour for it to come back on. Decided I better make a "redundancy" system. That was the last bulb I had on hand so went to Ace Hardware and got 4 more bulbs (250w IR) and another lamp fixture. One of those 250w rated fixtures for chickens.
I already had another 35F thermostat switch so was able to use both switches with the new heat lamp added. "They" say tomorrow will be the last day in several weeks where the high temp gets above freezing! Some of the highs won't be above zeroF!
Why didn't I move south years ago?
Then our daughter wants me to make a "heated cat shelter" in case the missing cat is still kicking and comes around with the plummeting temperatures. She said to use the cat's litterbox. I'm working on that too. Hard to tell the little almost 33 year old girl no. Last time the cat was seen was about 10 days ago and she ran off over a month ago.
