Dug these two snowthrowers out
That is a huge block of misinformation right there. Aside from the cell phone battery part. They can and will burn in a spectacular fashion.
Every article you linked was spraying lithium grease. Aerosol lithium grease would explode or be flammable due to the propellant just like WD 40.
While both lithium grease and lithium batteries contain lithium, the form of lithium used is different; in grease, lithium is typically found as a lithium soap (like lithium stearate) which acts as a thickener for the lubricating oil, while in batteries, lithium is used as a reactive metal within the battery chemistry to store and release electrical charge; essentially, the lithium in grease is not designed to conduct electricity like the lithium in a battery.
The lithium in grease is not going to explode if it comes in contact with water. I really doubt you'd be able to walk into walmart and buy a big ole tub of lithium grease if it was going to act like Gizmo when it comes in contact with water.
Lithium grease is known for its ability to be water resistant and can handle wet applications. Some of our customers request lithium grease in their bearings and such used underground. Wet and dirty applications. I haven’t heard of one catching fire and exploding yet.
See, I'm not so old schooled enough to know any different. Dumb social media tells people to avoid lithium do to it being unstable when near water.
So, in a grease it's fine? :rolleyes: OK, you got me thinking. I do have lithium #1 grease, but I've been using it sparingly where water can not get to it.
It's in a 5-gallon bucket with a pump. I placed a plastic bag over it to keep water away. But I shouldn't worry then?
Back in school, I recall the OKC bombing was diesel fuel and fertilizer that looked like cat litter. So, I've tried to keep those things far away from each other too. I just don't like things going BOOM near me. :eek:
Use it wherever you want. Although in the state of California it can cause cancer!
That's an MSDS for Fram Lithium grease you'd get at say walmart or autzone. Tells you everything you need to know about how and what safety precautions need to be taken with it. Did read on an MSDS for the brand we uses at work it can cause reproductive issues....
We had a grease class at the mine probably 10 years ago. Learned more about grease than I ever wanted to know.
OKC was Diesel fuel and Ammonium nitrate. Never read much about that.
We used lithium grease with water contact equipment at my former job the entire 19 years I was there. What I mean by water contact is some was submerged the entire time with greasing stations above the water, and some was submerged, then would get exposed to air for awhile then submerged again. It was recommended in most of the applications due to it's ability to shed water.
Everything is known to cause cancer in California with that proposition 65 label plastered on everything!
I found another little Toro snowthrower free on the side of the road last night. It is a little different from my other one, but I think a lot of the parts are the same. I think I can make one good one out of the two. This one has electric start, but the gear on the starter is missing. I put a little gas in the carburetor and it actually started and the auger turns. That was all I did with it so far. The gas tank is empty, it smells like old gas so it must have been sitting for a while. I would guess it will need the carburetor cleaned. 6CA907C3-CACE-43F9-8596-2F77E9930455.jpegADB6BAE6-E1C1-495B-B3D3-499D9FD306A9.jpeg6123AC1D-501B-4286-8006-A9B607F18E29.jpegBB2802CD-6F9A-46C2-85DD-186660DB34A5.jpegC4279A7A-5CB5-4016-BDCA-931B937208F6.jpeg
