Aha, finally, an explanation of my tractor projects.
Boy, ain't that the truth!
I hope they have a good fire dept...
I hope they have a good fire dept...[/QUOTE
]Inever understood why anyone woujld live in houses so close together.
I had a set of 30 pound wheel weights that I started with. Put a 5 lb on the inside of that and a 10 on the outside bolting those together. That is what the bar sits in then to hold the extra outside ones.If I ever get around to building sleeve hitches, I was thinking they could be good weights on a gravel drag too but wheel weights was my first thought. The sets I have mostly have an iron sleeve with a set-bolt but one has threads on the bar with a knock off nut. I thought that attachment deal on yours was something I had never seen before.
Looks much better and will function better shedding off the elements. YUou are making me miss my carpenter days!
That was the abbreviated version. The full version would include all the parts of framing that makes you want to hang up the hammer. Like cutting through ceilings and having insulation and plaster dust sliding down your back. Sawzall blade giving a shower of sparks as it finds the hot wire that you didn't. Or the imprint a 2x can leave on your arm...... YUou are making me miss my carpenter days!
