Installed the pulley again after my repair. Put all of the guts back in and painted the clutch handle and rod. When they dried I installed them also. On my first attempt at adjusting the clutch I found it was either to tight or to loose. Once I figured out the pulley brake was causing my problem I backed it off and everything worked as it should. It makes a nice crisp snap as it engages. The bonus is my weld appears to be holding.
I moved on to checking the ignition system next. I hooked up a battery, turned on the switch, and ran the point by hand. Looks like good spark. While the battery was hooked up I tried the starter and got nothing. It looks like a new/rebuilt starter, but the contact switch is making contact. I need to play with it a little to see if I can slot some holes enough to make contact. It looks like the lug in the case is worn down to much that's causing the problem.
