Just had to do it.
Had to use some heat and cheater bar to loosen the worm shaft cap. Made a loud pop when it came loose and then threaded out mostly by hand. Removed the shaft seal and it is now ready to sandblast. Need to clean and check the bearing to see if it needs replacing.
The seals for the steering housing arrived today. Pulled the rocker cover and thermostat housing off and prepped for paint. The rocker cover has been mostly bare metal since I pressure washed the tractor just after I bought it. Now I can finish cleaning the front of the block and spray a little paint behind these parts before reassembly.
Cleaned up a few more parts and added the oil pan. Starting to suffer from mission creep. The pan was mostly bare metal like the rocker cover so I may as well add it to the paint list. Blasted the fan assy and boiled up the pan and steering housing to clean the oil and grease off. I used the hot water and a brush to clean the crud off the water pump. Its a little noisy when I spin it but the bearing feels smooth. Not sure whats up there. May need to replace it.
Broke out the hammer and dolly and finished smoothing out the oil pan. No perfect by any means, but good enough. I'll put a before pic of the pan as it was when I bought the tractor.
Finally got the steering housing blasted and treated with Ospho. Now to get set up somewhere to spray some primer.
I like the way you work young man. You see something wrong and you go after and fix it properly. As my grandpa told me a long time ago in a land far far away, "take car of your equipment and it will take care of you!" It's worked for me for a lifetime.
Keep up the good work.
Thanks, Cvans. Its gotten more involved than what I first figured I would have to do, but then I won't have to go back over this ground when I do paint the rest of it.
Its gotten move involved than what I first figured
You've just learned a very valuable lesson. When buying something as a project always allow yourself at least 50% more cost and expense than your planning on and then you might still come out short. The other is something will look 30% in the photos than real life.
Don't mean to be discouraging just trying to help you avoid disappointments.
No discouragement here. I told myself that I was just going to change the front oil seal and not worry about anything else until I do a big tear down for a paint job. Then when I get into it I get the mission creep. Already made the big investment in this tractor when I got the $1500+ rear tires. Thought it might need an engine kit also but that seems good for now. Should be some warmer weather this weekend so I hope to get the painting done.
It is a little sad when the rear tires on most of these older tractors sometimes exceed what the tractors worth.
We bought the exact same tires for our Farmall Super C about 5-6 years ago for around $700. Most of the parts for these tractors have taken a big jump in price. The upside is these tractors are far cheaper and built better than the new stuff. I also look at tires as a consumable item that need replacing occasionally. As long as I don't rip one open on a chunk of steal or something I shouldn't ever need to buy tires for this tractor again.
Bought a new water pump because the bearings were noisy and probably not far from failure. Shot some primer and paint finally.
