That was my thought too, probably dipstick holes, just don't understand the putty stuffed in the holes.All good Doug. Just glad to be able to chat back and forth.
That plug is probably for a dip stick. Depending on engine application.
I ran out of patience on that clutch for now, but I quit before it got destroyed at least. If the crank comes out of the block that direction, is there an outside chance it can stay in place? Didn't study that part much yet!Yes, besides the electromagnet, this bolt holds the moving parts to the crank. Often times it's hard getting it to slide off crank, as the keyway will hold things up, but it will come off with patience.
Thanks for the advice, Noel! Yeah the oil hole is on the cam side. I have been taking more pictures than what is being posted here to help my bad memory. Then the manuals Kenny and Gary posted will be a great help too. I know automotive pistons all should be marked for position. I built a lot of Briggs 5 hp back in the 80's and 90's but I can't remember much about that including piston position!That’s lookin pretty good Doug. One I thing I want to mention. When you put the rod back in make sure that hole in the rod is placed in correctly. That hole, if I remember correctly, goes toward the cam. Do your research on that Doug to make sure. Engine don’t run to long if in the wrong way. It won’t lube the rod and crank. I know that now !!! And the piston has to go a certain way also. It may have a notch on the top. Notch goes either toward the flywheel or pto end. Again I can’t remember for sure. Do your research. Now would be a good time to clean up your stator and magnets in the flywheel. And make sure the magnets are tight. I did that to my John Deere engine this summer and it seems to charge better.
I almost pulled them last night but had to quit for the night. Had a sign job come in today so worked on it rather than going out in the cold work bay. Pretty much just stayed in the shop office. Thanks for your comments, Kenny!On the PTO clutch, remove those 4 Bolts at the block also. Think the bolt in the crank is in case the bearing fails, the pulley doesn't go flying off.
Thanks Noel, it is off! Don't think anything got damaged! Didn't get pics of the removal. There was no space to get pry bars behind it at first. I had taken your advice on making sure the key slot had stuff sprayed into it and was soaking and I think that was the biggest help!Hopefully you don’t have to do that Doug. Can’t remember if I ever had trouble with getting those off. But it should slide right off. If I remember right. Spray some stuff in the key way too. Then I would put three prys in behind and put a little pressure on it. Pry a 12:00 o’clock, 4 and 8. Then I’d use two small hammers to tap it lightly. Holding one hammer on it then tap with the other from the opposite side. Keep adding a little pressure to prys. Then if that doesn’t work I'd try a litte heat on it. Put don't redden it. Just a little heat.
Just some thought Doug. Not sayin it’s the right way. Hope fully you get it off.
Thanks, Noel. I don't want to damage the points rod bore so it will stay there for now. I haven't decided if the cam is coming out yet. Looks great and no wiggle on the shaft or end play. Looks like there's a rod thru the center of the cam that would need to be driven out to remove the cam. If the block has to be bored, then it has to come out. I think I can hone the cylinder with the cam in place if standard bore will be ok. Will need to do some better measurements.Rod must be mushroomed a little at the inside end. I’ve never had that trouble Doug. So not sure what to say with the points rod. If you take the cam out, I guess take it out that way.
Good you got it apart.
I will do that Daniel! Hope it's ok. I did notice the fuel pump cam looked real good. Too cold to go work on it tonight.Check the cam where points pin runs. Some cams will wear there so much that the points can barely open.
I have no idea on cost, Noel. Sometimes it would smoke for awhile on start up but it seemed to go away after some warm up time. Daniel had mentioned earlier that the oil rings might be collapsed, and eyeball wise it looks like it. They didn't expand near as much as the compression rings. Possibly that is normal though. I am leaning toward the standard bore rebuild kit.Was the engine smoking bad Doug when you had it running. Maybe I asked that before. Any way can’t remember if you told me any thing or not. ??? Hehe. I’ve never had one bored. If it looks reasonable I just put new rings, maybe piston and a rod in. Put er back together. Mine have all run fine. Ya they might burn a little oil and maybe not, I don’t get to concerned about it. What would it cost to have one bored out. ?
160 bucks for two cylinders sounds like a reasonable price, Roger. Probably be twice that with the crazy prices everyone charges for services up here though!Had one bored last summer. Briggs L head twin 16. Rings were broke, walls scored, etc. Bored 0.010 over. Put new pistons, rods and rings in. Have a new gov. spring to get it running right but ran really well at 2/3 throttle. Cost me $160. Took them a month to get to it.
