Snapper made the smaller Massey as well? MF7?
No they did the later 70's into 80' 1000 series ie 1100-1855'sSnapper made the smaller Massey as well? MF7?
Spent an hour visiting with Doug on the phone. Think we both understand his situation better now. We'll get this MF going again and working as it should (even though I am no guru on this brand of tractor). Any help you folks out there can give will be appreciated!
Yes, Kenny I really enjoyed talking with you about this thing! For now I'm going to gasket the engine mount plates but will try to fix it better later.Doug. do you have the engine #'s handy (type included)?
The float position does work too. I knew up and down worked ok, When I put the lever in float today it dawned on me to reach down and move the lift levers and they did. Won't move much in any other position of the lever. Like I said earlier, the lever stays anywhere I move it to. I will order a new cap, and need to get a seal kit to get the valve to work smoothly again. 3 point valve works great.Float is down on the Massey's. I have a spare set of valves, let me know if you need any measurements or info Doug.
Yes sir Noel, great members, great forum! I am glad to have you making comments here too even though this tractor isn't like any of yours. Your common knowledge about tractors in general is very valuable! Plus boosting my confidence a little bit when I'm ready to part this thing out is priceless!Like I said before,
Doug go ahead and whine here. Your wife doesn't want to hear it and wouldn't know what you were talking about anyway.
Makes for good reading and seems like your getting plenty of good help.![]()
Oh I didn't get to the next page when I replied, Jason! Guess I jumped to conclusions when I said my 12G is a Snapper built tractor! Obviously it is not a 1000 series! Who built them?No they did the later 70's into 80' 1000 series ie 1100-1855's
After seeing your engine pics, I see the pan I have won't work with your engine mounts. It would rise the engine about 1.5", creating a driveline mis-alignment. Here's a pic of the oil pans available for the K321.The lever came from Kenny today so I did some test fitting of the cover I got from Daniel and installed the knobs on the levers. Nice to see something on this cobbled up tractor that looks kind of like it is supposed to!
View attachment 49541 View attachment 49542
Speaking of cobbling, I built gaskets to sandwich between the engine mount plates and the incorrect block where oil was seeping. Hope it will get it by for awhile until a more correct fix can be accomplished. I need to get the tractor out of the shop for a while, and I want it to be under it's own power.
View attachment 49546 View attachment 49544 View attachment 49545
I don't see the ring in the pics above.The one on my K321 is #5 base and #2 gasket.
I wonder if Doug’s engine have the alignment ring on it, for the power king bell housing. Gary was mentioning that before. Another k321 engine I have has the alignment ring and has the block base like Doug’s.
This rambling doesn’t help Doug in any way. I’m just rambling.
Oh yeah! I remember now that you reminded me! Thanks, Noel! Probably back in 2015, when I repowered the 12G, I had asked about "Canada" being casted into a iron pulley. Someone told me about AMF being the manufacturer. After owning these machines for so long, I forget what I learned about them in the past! Only thing different is the hood and grille.I think AMF built them Doug. Look at the sheet metal around the fender area.
That sure shows the varieties, Kenny! My tractor requires gasket 2 and pan 4 obviously. Have the engine for pretty much all the other bases pictured!After seeing your engine pics, I see the pan I have won't work with your engine mounts. It would rise the engine about 1.5", creating a driveline mis-alignment. Here's a pic of the oil pans available for the K321.
The one I was thinking about is either #3 or #10. What you have on there is #4 (usually found on JD tractors). My next thought is getting both the #1 and #2 gaskets and make a plate (1/8" thick) that fits between your block and pan, effectively sealing the cutouts for you. I'd use the gaskets to layout where all the bolt holes need to be. Hope you understand what I'm trying to get across.
Not quite, Noel, but thank-you!She’ll be just like new Doug. !!!
