Looks like someone put a 100lbs of air pressure in it.I think that tire has a leak Doug. !!!!!
I put 15# in it for this leak check, Chris. Guess that was more than enough---LOL!Looks like someone put a 100lbs of air pressure in it.![]()
Hey, Noel, thanks for your patience. As you know I just can't get on the 'net until later afternoon, which is probably near your bedtime clear out there at PEI!So Doug. I want to know what you say before you take it apart.
Thanks Daniel. I would even consider re-powering this thing but with having that driveshaft splined hub bolted to the flywheel, I think it pretty much has to be a Kohler.I hate to hear of the metal in oil Doug. Man, this thing has been a bugger, and continues to be! Hope your luck turns to the good SOON!
If you have a local buddy with a metal lathe, one could turn an adapter easy enough. I've made them to adapt to Onan before.Thanks Daniel. I would even consider re-powering this thing but with having that driveshaft splined hub bolted to the flywheel, I think it pretty much has to be a Kohler.
The guy at work who built the driveshaft for this tractor could probably handle it, but it would still have to be an engine that has some sort of provision on the flywheel wouldn't it?If you have a local buddy with a metal lathe, one could turn an adapter easy enough. I've made them to adapt to Onan before.
Many engines do have tapped holes in flywheel, as a lot of power equipment drive things off flywheel side as well as output shaft.The guy at work who built the driveshaft for this tractor could probably handle it, but it would still have to be an engine that has some sort of provision on the flywheel wouldn't it?
I doubt Predator engines do. Think they have plastic flywheels too. The V-twin is outa my price range.Many engines do have tapped holes in flywheel, as a lot of power equipment drive things off flywheel side as well as output shaft.
Been thinking on what it could be, but no light went off in my head yet.
