Ceiling fans help some too. Push that warm air back down where it belongs! I gave up the wood heat stuff many years ago, Noel. Glad you guys have a good system to stay warm!
Got it pretty nice out in the work bay today. Wasn't feeling the greatest until after noon. Got a shingles shot yesterday, right arm ache and just felt kind of sickly, moved pretty slow. It wore off faster than the first one at least! Arm is still achy but got house chores done while the shop warmed up where I like. 68F. Got flowers for tomorrow but used my head this time. Instead of running into town, I pre-ordered them on line, and delivery only cost 12 bucks! I was outside scraping ice on the areas where we have to walk when the delivery lady showed up so that went well.
Anyway I did tinker with that 1450 a while. These parts came in so plenty to do. Goal is still to get it running first, to be sure that it will move under its own power in both directions. Other issues like the steering box will wait until movement is confirmed. Here's the parts.
Crankcase breather tube has me baffled. I got the breather cover gaskets because the lip of the old tube is visible inside it. Carb has no port to hook it too. Done quite a bit of parts manual studying but not much engine info in them. Need to do more net searching.
Took the fuel pump apart to put the diaphragm in and bad news. Not sure if it is rebuildable. Kit didn't have the little flapper and the check valve looking parts. Badly corroded. That is the reason why I ordered the new pump. It is a plastic pump but may work for a while.
View attachment 34319 View attachment 34320
Then, attention got diverted again. Started the air compressor to blow out the parts and it took too long to pump up. It did finally shut off then I could hear a leak. Sprayed soapy water on it and the main female quick connect was leaking. Ok, I have a spare one. Drained the compressor and replaced it. Still took longer than normal to pump up. It shut down and still air seeping somewhere. Couldn't find anything with the soapy water. Had to drain it again, remove the new coupling and take off the cover. Long story short, it is the pressure switch diaphragm that's leaking. Might be time for a new switch. That one is pushing 50 years old on this 1973 Craftsman/Campbell-Hausfield. I'd love to get a new one but out of my budget right now. Didn't take it further apart yet as may need air for tires during this arctic cold snap.
View attachment 34326 View attachment 34327
