Goal was to have it done for the show. She won't be attending the show, she lives an hour away.That's a beauty, Ted! Was your goal to surprise her at this show?
I think I would too.That is one nice looking Allis, I'd take to the show even if it isn't quite finished
The drive belt for the tiller installed. I still need to get a seat and finish the wiring. I also have the gas tank with rust remover on the inside soaking. It was one of the worst gas tanks I have seen on the inside. After the tractor show today I will dump out the cleaner and see what it looks like on the inside.Who can afford green or yellow paint?You need banned for those type of comments![]()
Hard to afford any color of paint these days. The 1/2 gallon of Orange and 1/2 gallon of cream white with reducer with my discount was close to $200. And that did not include the primer or clear coat.Who can afford green or yellow paint?
The back part next to the dash needed lifted up to get thWee tank where it should be and the fill hole where it should be in the hood. I took out some of bend reinstalled it the tray. It fixed the fuel filter issue.
I also took the trailer to the back yard and loaded up the tiller and mowing deck. The mowing deck needs all bearings and some welding done to the middle of the deck.
Thanks DACLooks great, Ted!
This is a 48" deck, the other option is a 42". I bought a couple of JD decks at auction a few years ago. I am going to see what shape they are in, if in good shape I will take the mounting brackets off of this deck and on the JD deck. I can't remember how wide the JD decks are but I remember they were less than 48".I think the deck on my JD110 is a 38 or 40". Obviously, they made bigger ones though, Ted. All those protective covers on mowing decks make it impossible to clean all the debris off the top of them and most people won't pull the deck to remove the covers to clean them. They go away on my tractors. Then I can blow everything off with compressed air after every mow.After work I stripped down the deck to see how bad of shape its in. It is in real bad shape, lots of patch panels welded on different places. The main part looks like Swiss cheese.View attachment 99096This is a 48" deck, the other option is a 42". I bought a couple of JD decks at auction a few years ago. I am going to see what shape they are in, if in good shape I will take the mounting brackets off of this deck and on the JD deck. I can't remember how wide the JD decks are but I remember they were less than 48".
The deck I use on my 12 I have taken off the belt guard to make it easier to clean off.I think the deck on my JD110 is a 38 or 40". Obviously, they made bigger ones though, Ted. All those protective covers on mowing decks make it impossible to clean all the debris off the top of them and most people won't pull the deck to remove the covers to clean them. They go away on my tractors. Then I can blow everything off with compressed air after every mow.
No comes the fun part of stripping it down and getting the Allis mounts attached to it and then repaint it white. The 2 ears on the back will have to be plasma cut off along with the front roller. The only rust hole is over by the discharge and the size of a penny. The deck mandrels need new bearings installed. The drive belt will need to be a little longer, the front of the deck to the center of pulley is 2" farther back. I did forget to measure the deck width front to back to make sure the Allis has enough wheel base.
