Started a simple little job for the MF8E today. It has a 42" blade from a Cub Cadet on it and the litttle round skids have always been hard on a gravel driveway. I'm taking a piece of 1-1/2" pipe and going to weld tabs on it to bolt into the skid holes. I did that idea 20 or so years ago, building a "scarifier" in the same manner. I'm not sure if that is the right term. I used it 2 or 3 times to break open the hard-packed dirt surface on the go-kart track I used to host races on. It worked fine but I had to quit the racing as liability worries outweighed the fun. Whatever steel I dug out of my scrap to make tabs with, cut fine with a cut off wheel but sure wont drill! It isn't stainless either. Killed several drill bits trying to work up to a half inch hole! I'll dig in the scrap at work tomorrow and see if there is any 1/4" flat stock scraps 1-1/2" wide. Only need about 6"!
Only got this far. Cut the pipe and have it against the scarifier so I can get the hole right to fit the blade.
