You already had the engine?Well the Husqvarna tiller is a no go! Trans has stripped gears in it! Gonna use the Predator engine elsewhere. Look for a new thread!
Nice solution for the problem!By putting the sleeve hitch on the Speedex I had nowhere to hitch up either of my wagons or the sulky. So I made an adaptor to mount on the sleeve hitch so I could pull something with a tongue. I had a piece of angle iron that was the perfect width if I welded two pieces together. After drilling two 5/8ths holes I found spacers the right size to hold that dimension while I welded it. A third piece was cut and drilled, then welded on the side.
After welding , cleaning and painting it fits nicely on the sleeve hitch, using the adjusting bolts to snug it in place.
I have found that a 4X4 (3.5" X 3.5") is just about perfect for the bottom of the weight to rest on for installation/removal. Keeps your finger from between it and the floor.Working on two flat tires this morning. Front on the H16XL with front blade was flat yesterday in the shed. Tried to air it up and found a short split in the center of the tread. Have to replace that one. Second one is the rear on the IH 1650. 12" wide tire with chains and 75 lb weight. Slow leak that need addressed before winter as that has the snow thrower on it. Biggest issue is getting that weight off and back on without smashed fingers.
That works good Kenny. I have a light duty floor jack I lay a 2X6 on and the weight on that. Actually, getting the weight on the wheel is easier than getting it in the right position. Maybe we need a H&**(%@ ?I have found that a 4X4 (3.5" X 3.5") is just about perfect for the bottom of the weight to rest on for installation/removal. Keeps your finger from between it and the floor.
Naw! Just a sky hook! But I seem to have misplaced mine!T
Gauge should come out top side, but there is probably a u shaped bracket on the backside clamping it to the dash. Usually just one nut holding it on.I would like to get at the amp gauge, on the dash, of my 446, 1982 Case. Seems like every thing in the way. Does it maybe just pull up out of the dash. Took the steering tower cover off and ya can’t see nuthin. Same with up top. And the tower all one piece. Don’t see any where to remove it.
Anybody have any ideas. Thanks.
