Nothing tractor related.
Yesterday evening my front door wouldn’t open. It would partially pull back the latch but not enough. Used a butter knife to pry it back just enough to get it open.
I’m odd but I figured that door knob did door knob things for 50+ years I might just be able to save it and let it door knob a bit longer.
Took it apart. Cleaned everything out. Sprayed it down with some dry lube. Made sure everything was free and clear. Filed down a couple burrs. Put it back together and it works like a new one.
It’ll get replaced in the future but it’ll be just fine for now.
ran into a snag on K301, x2.
ruined the starter/gen pulley on it. I'm glad the other one came off so easy. and that I have lowered my standards/expectations to getting 1 good engine from 2 engines' worth of parts. I was originally gonna build both of them up even though I don't have a machine here for the 2nd one.
I actually bought the puller that "parts by Jeff" (member on more- Cub cadet-centric sites) over the summer, "for" this job. I put this puller he made onto the pulley on engine #2 back in like, June or July. I left it sit on there, since like the day after I got it, under tension this whole time.... thinking it would finally (eventually) give in/ being that I didn't have to be in a hurry for that one. I actually forgot about it, as I've done a few other things since then.
Over this past weekend I was moving some stuff around in the garage, and got tired of moving them. so they're past time to be taken apart for eval/inspection anyway.
I have most of an 85 Dodge D-150 sitting behind these and a Swisher trailmower, that I want to make some progress on over this winter.... which involves getting that D150 over to the other bay of the garage where my 2 post lift is..... and this stuff has to move, for that to happen.
I acquired all the parts, every little bit needed, to convert the truck from auto to 4 speed stick, unexpectedly, 2 weekends ago so that project is going in a different direction, as soon as my new clutch gets here. Plans are to take the flywheel for that to the machine shop to be resurfaced, when I take 1 engine's worth of K301 parts to the machine shop. (I wasnt thinking that way, until a buddy of mine in Indy who has my truck's twin, decided to do some garage cleaning and made me an offer I couldn't say "no" to.)
I took the puler tool off that engine and put it on K301, x1 and it worked like butter. Back on engine #2 and.... nothing. I sprayed and sprayed and sprayed that thing, over the past couple months, in between sprays, I emery cloth-ed the snot out of the crank on engine #2. so I pulled the tool off, and got the big oxyacetylene torch out, and heated the hub cherry red. I gingerly put the puller back on. Wouldn't budge. Repeated this a few times, as soon as the redness left (parts were still hot, mind you) it wouldn't budge.
So I put a ball joint/tie rod seperator in between the block and pulley, wedged a tapered chisel in between the skinny tips of the ball joint tool. It moved a hair. I had taken the purpose built puller off, since I managed to pull the threads out of it..... I get the hub cherry red, and heard all the "grunting" sounds that heating metal makes, (usually when the bond breaks) and went at it with hammer, chisel and ball joint wedge from behind the pulley. . every time the "red" faded away it stopped moving. I had to keep that hub cherry red for it to keep making progress towards "off".
By the time I got the hub flush with the end of the crank, I had mangled the thing. so now it don't matter if I cut it off, its FUBAR'ed anyway.
I haven't touched it since it rolled off the table I was working on, and hit the ground. I did get the square key driven out the back side and completely out of its groove, which made no difference. I ended up dismantling the rest of the engine, all that is left of that engine is the block, crank and the cam bobbling around in there since it won't come out with the crank in the way. so now out comes the cutoff wheel......
Finally got the mangled pulley off of the crank so I could finish disassembly. It took a grinder and a cutoff wheel to do it, had to cut the outer part of the pulley off so I could get to the hub.....
So one day next week both blocks and cranks go to the machine shop to see if I can hopefully get 1 good engine between the 2. The gray one has a chunk out of the bottom of the cylinder bore from where the rod remnants smacked it, but I've seen worse salvaged. The yellow one is just egg shaped and plum wore out. Both cranks have issues, the one from the gray engine gas a fouled up keyway it would probably be alright if they can cut me a new keyway across from the original one.
The crank out of the yellow motor I discovered after cutting the pulley off is mushroomed right at the end, wouldn't take much to clean that up. The gray one also has a little aluminum buildup on it, I don't have any muriatic acid on hand at the moment,
I'm thinking that one has a better shot at cleaning up with a polish job on the journal than the crank out of the yellow motor, I think they could polish the journal on the gray motor crank and cut a new keyway in house I know that if either needed ground this shop would have to farm that out.
*#@*$&@*@ Chrysler engineers......working on my sister's Dodge Journey. It honks the horn and flashes lights whenever. I researched it and the TIPM i.e.fuse box develops shorts as they designed it with internal relays on a printed board, we got a used unit from junkyard. Well you have to unhook both battery cables and connect them for a couple hours which drains all the relays/capacitors/etc then you do a key reset once new box is on to relearn system. Well the freaking battery is in the wheel well in front of the tire.....What the...???? Who does this crap? On top of that, the used box must have a short in the trans module circuit cause it threw a code and won't shift so I had to put old one back in until we figure it out.
I wasted 6 hrs farting with this thing and back to square one. Ugh!!
Yeah they couldn't have left things that worked as they were, alone, huh. So many of the newer "designs" are total crap. I am a big participant in a thread elsewhere that has turned into a bash on " engineers" that started about another member there starting off about how stupid it was for them to put so much plastic in car cooling systems like thermostat housings, manifolds, radiators ....
My son has a 02/03 Dodge Ram 1500 it’s been a good truck mechanically with over 354k miles minus the rust and it being an electrical nightmare at times. The worse I’ve ever dealt with was his headlights went out. I done everything you could do but no lights. I went on YouTube and one guy had the same problem. That year they put weep holes in the fuse box not thinking about salt water getting in there. Dealer wanted over $1500. to fix and a used fuse box was running around $600. What I done was removed the entire fuse box, took it apart revealing the very small section of the circuit board that sit right over one of the weep holes where it corroded. I cleaned that up and soldered a jump wire for the fix. I went ahead and sealed the weep holes with silicone. That’s been about ten years ago with no problems.
I feel your pain on the Dodge Journey, Marty. From what i understand the Journey was some sort of Fiat design. We had a 2011 for a while. It did us pretty good, but then a noise started. I used my old fashion stethoscope and determined the alternator to be making noise. This was back in 2014. It was fairly new and under 100,000 miles. Took it to the Dodge dealer and they said no not the alternator. it was an idler pulley. I figured these "technicians" new better so went with it. They had to order an idler pulley and it would take ten days to get there. They said it would be ok to drive it until then. 5 days later about a half mile from home, the battery exploded! Had to pull it home. Glad my wife almost made it home! Alternator overcharged and blew the battery up. I called dodge town and told them to cancel our appointment as I must be better at troubleshooting these modern outfits than a "tech" is. And yeah, pull the left front fender well out to access the battery. Bought an alternator, serpentine belt and battery. Should have sent the bill for those parts to dodge town but decided that I have to do the work on our stuff again until we can afford something brand new for her to drive, then the dealership can do it. If you ever need one of those sockets for the rear brake calipers to screw them back in I got one I will send you free of charge! We traded that thing off for an older vehicle a 2006 GMC Denali in 2015. Still driving that Denali, and my wife finally got our first new car in 2021, a Chevy Equinox.
The Denali has had some bugs but nothing I couldn't fix so far. They wouldn't give enough trade in on it to make it worth it so I drive it a lot now.
And one more rant about engineers---a guy at work is always saying there should be a hunting season on them with no limit---LOL! Pretty unbelievable how a bunch of us uneducated idiots have to fix the messes that engineers designed and signed off on when projects get done. Some engineering problems never get fixed, it just costs a pile to keep things working.
One of my tractors I got at a farm implement dealer in Orient, OH and one of there mechanics had put new rings and only spaced the end gaps within a 20° space on the spark plug side. I got tried of the blowby I took it apart and had to clean the groves out, turned the piston around , put the rings on with proper spacing and about a year or so iy split the piston.
Now for what I worked on yesterday. My hunting blynd had a broken end board so I and the land owner repaired it. We add onother board under the broken one and also scabbed one on the other to support the floor. There was one board supporting the floor and put a new one in. I was the board on the left. This is the day we put it. It has a heater and an office chair.
What is that made of, some type of plastic boxes or walls?
I accidentally dropped the old fuse box while I was inspecting it after I removed it. Well due to the new-used one being junk, I had to put the old one back in. Sister reported this morning no horn honking or parking lights flashing....maybe I fixed it or it was just loose/corroded harness connections.
I only had a few hours today before the games came on. I had a trailer full of mulch from a couple of weeks ago chipping I needed to empty. I invited a couple of friends out to hunt this weekend so I used the four wheeler instead of a noisy tractor. I cleaned the chicken coop out and spread the mulch around their coop and run. I picked up all the corn stalks from the Fall decor in the yard and took them to the burn pile. Got everything done and still got to talk to my friends for awhile.
It is made of plastic and from a factory in TX, It is a 4 x 8 size and they make a 4 x 4 size also. I got this 20 years ago and had it in WY till 2009 when I put the property up for sale.
Went to the shop yesterday morning to work on a John Deere 110.A gentleman was coming to look at it. It had the snow blade hanging off the front but it still had the mower deck on it. He wanted the deck off of it and the lift rod installed. He showed up at noon walked into the shop and never even looked at the J.D.. He spotted the Wheel Horse D160 and had to have it. Needless to say I sold it to him.
Shortly after he left I got a text from a young man who had been here before for some Sears parts. He was coming back for the rest of what I had. He didn't have enough money the first time. It was over an hour drive for him so I had offered to let him take it all the first time and send me what he owed me. He said it would take him a while to save up the balance and didn't want me to wait and wonder if he would actually pay me
So he made a second trip. He wanted two belt covers for a Sears XL10 and a starter generator with mounting bracket.. I threw in 3 extra S/G,s plus the hitch plate, front axle, spindles and transaxle off of a SS16 I just bought for the fenders. He also got a second set of rims to put duals on his tractor. He left grinning ear to ear with the rear end of a small SUV squatting on its' springs.
You are a tractor flipping parts dealin' guy, Rick! I only know one other tractor guy around here and the only stuff he wants is what I want to keep---LOL!
Spent this morning to early afternoon getting ready for the blizzard Tuesday and Wednesday.
Moved 3 trucks to the backyard so it would minimize the drifting for 25 feet or so just south of the overhead door on the shop. Probably will be a 4 footer right against the overhead door but it won't be real wide. My wife's Equinox will go in the shop, as she won't go to work until Wednesday morning if we will be able to get out. The Denali will go just to the right on the concrete.
Then I brought into the house some stuff to be prepared in case the power goes out. A little Mr. Heater will be enough to keep the chill off, Old Coleman lantern and cook stove for light and hot food/coffee, and an assortment of flashlights.
We will fill the bathtub with water tomorrow afternoon. Son brought by a couple 35 bottle cases of drinking water yesterday.
Then I got the MF8E and the little snowblower in position to go to work. Still better check the air in the tires thoughDSCN4918.JPG
Then after that, the part that hurts this old geezer had to happen. I got new cartridges and fresh hoses for our RO drinking water unit in the kitchen, under the sink. I replace the cartridges and filter annually, but the hoses are now 17 years old and seems like when I move thing around under the sink, leaks at the connectors develop. Put fresh tubing in and some new connectors. Won't know until tomorrow if it pressures up right. Had no leaks at least! No pictures of that adventure.
Now we wait and see how much of that damm $@#% we get! It was beautiful today, wish it could stay that way!
WE have had a couple case of drinking water for some time now so good to go there. Have an outside single holer when needed. Couple Coleman lanterns with fuel ready. Enough wood to run several days constant running in the fireplace so will have some heat. Now we wait and see but looks like mostly rain. Wind will be the big thing.
