Your depth adjustment works good, IF the sleeve hitch on the tractor is at the same height as the cultivator hitch. I had a lot better luck doing the adjustment with the tractor up on blocks the depth you want to run and then do the point adjustments with tractor and cultivator on level surface. Front points always go in the ground first.
My brothers' Cub Cadet was sold back in 2021. I have no machine to adjust towards. I've looked at what I've seen on a few YT vids and did my best from there.Ypo
And before taking it totally apart, I did take some measurements to match his old machine it was used on. He took the wheels off years ago. Where they went is unknown now.Without a tractor hard to make adjust attachment work right/ You have a real good starting point for sure.
I spent 1/2 the day row cropping in sweet potatoes. We have a near perfect soil for them here. Also, peanuts grow well in this soil too.I have the wheels for one of mine but never used them. My sleeve hitch is winch operated. Last time I used the cultivator I had to put a cement block on it to get it to stay down but had sweeps on that one. Lot of green starting to show up but ground way to wet to work yet. Slime chance tomorrow afternoon it will be dry enough. Probably put a good layer of grass clipping around the plants and wait on the rest. No row crops planted, no veining crops planted either. Ground has been to wet for the last 6 weeks.
keep us posted please!Replaced the tired B%S motor on the tiller with a new Predator 6.5 hp.. Will try it out in the morning.
Gt235.... Johnson outboard? HahaGetting my GT 235 ready for classic iron show this weekend. It's almost ready.
Motor started first pull. Ran about 2/3 throttle for the first 15 min or so, then ran it a bit faster. Never did get to full throttle. Tiller has 2 speed forward and one reverse on the tines. Ground was hard and did a lot of shaking and some bouncing the first tim over but never did hear the governor open. Would have killed the old motor several times in that ground but this one just kept right on purring through it. At this point very happy with the predator. Strongly considering getting a twin around 16-18 hp for a White Yard Boss GT with a heavy smoking Onan engine.keep us posted please!
Those Predator engines are being used a lot. Most everyone says they are reliable, easy start, and reasonably priced.Motor started first pull. Ran about 2/3 throttle for the first 15 min or so, then ran it a bit faster. Never did get to full throttle. Tiller has 2 speed forward and one reverse on the tines. Ground was hard and did a lot of shaking and some bouncing the first tim over but never did hear the governor open. Would have killed the old motor several times in that ground but this one just kept right on purring through it. At this point very happy with the predator. Strongly considering getting a twin around 16-18 hp for a White Yard Boss GT with a heavy smoking Onan engine.
I have a 6.5 on my 3pt tiller and a 420/13 hp on my sears, both with start right up even after sitting a year with bad gas. They've been good to me.Those Predator engines are being used a lot. Most everyone says they are reliable, easy start, and reasonably priced.
