They would have worked for that.
Rick, my biggest issue is eyesight, I'm very near sighted and need bifocals, I have to be in a position to see well and be able to move.
I started being over the top of the gun and moving it straight backwards, but then switched to having it angled to one side so I could see the side of the gun and not over top. This also helped me move it easier and make a longer pass before stopping. I made it in 2- 1/2 length passes around versus starting at 3 to 4- 1/4 length passes
I have the same issue besides being shaky, Marty. I haven't gotten any "cheater lenses" yet but I do take off my regular glasses and put on readers. I think Daniel and a couple other guys on here use cheaters. I got a Viking helmet a couple years ago that made a huge difference in visibility. Welds are still ugly but at least I can see the mess as I'm making it instead of a surprise after I lift the hood---LOL!
When I reached over to turn off the pump, I guess the jolt of the pump shutting off is what caused the pipe to blow. My unlucky butt was standing right by it, I got sprayed with probanly 150-160*water. I ended up with 1st and 2nd degree burns up my leg, some on my stomach.
View attachment 90891.
OOOOO, oh ouch Marty. That sucks! :eek::(. I’m glad your on the rebound now though. Did you rub a little dirt on it then walk it off, or did you have to go to the hospital for it to have them look at it or get medicine?
No dirt, a lot of aloe and antibiotics cream.
Now I'm at the drying out,skin peeling and it's starting to itch real bad phase. Most of pain is gone other than 2 still tender areas.
Installed a new rear caliper on the '05 Liberty, it was starting to lock up the last 2 times I drove it.
Then I cut up a couple skids I got fron work to use as kindling although one skid was true 2x4 and 4x4 oak runners.
Then I swapped in a new lower hinge on the Dodge, the door has been sagging pretty bad. The top one needs replaced also, but it requires I remove the e-brake assembly off kick panel so it can wait till it gets warmer. Door shuts a little better, but still not perfect.
Now I'm eating dinner and watching the Xfinity race.
Finally finished cleaning out moms house. Gobs of aggravation and angst there, I had a long post about it, ended up somehow double posting, edited several times, didn't realize the edits were being done to the 2nd posting of which is deleted so I deleted the original one too as I ran on several ideas together that didn't make sense. (Which was what I'd corrected in the 2nd posting and didn't realize and deleted first once I realized I'd double posted ... ) .
Today I went on a CL/MP wild goose chase, made a couple of stops near each other but each an hour and a half from me, for parts for the truck I'm putting together this summer. Brand new stuff that I can't buy from the company for anywhere near the same price.
From the 2nd one I also got a "build your own wagon" kit from Sears, new in the box from at least the late 70s, identical to one I'd gotten for Christmas while I was in grade school and then my dad built for me ... I'm gonna put this one together for the grand kids.
Back when that kit was made, no explanation was needed that wood needed to be bought. Nowadays---oh well!
Sure hoping for a turn for the better from the sub zero temps so I can take my shop furnace apart and install a new heat exchanger. Too dang cold to work in the lift bay, even limping the furnace along.
