well, so far so good on the K341 in the Ariens....have fired it up a few times now.... and retorqued the head gasket.... though I have it inside the garage right now, which is currently 70*… I need to park it outside a while, and see what it does.... it started fine in the garage last week and then again this morning, before I had it apart // but last week I pulled it out to do a "side job", and when I went to start it to pull it back in, it sounded like a shotgun went off a few times, before I finally got it to run,. to bring it back inside..... it was in the 20s outside/ and it had been outside 4 or 5 hours at that point..... last winter, I wound up having to replace points in that machine outside, when it was 10 or 15* below 0, burnt them up, for some reason.... and that burnt up set of points wasn't that old, at that time.... few months worth, and probably about 5 hours on that set, at most. yes I replaced condenser with that 1st set of points, had to... due to rust and corrosion. The whole ign system is new on this tractor. coil, ign switch, plug, wire, all of it.
it always has started easily even sitting outside since I initially got it running, as long as it's above about 40*.
even being inside, and being allowed to sit for a couple of hours between starts to get good and cold, it does seem to be starting with less cranking of the key than it had been before, since the valve job.... and strangely, even though I have only put about 12 hours on it since the initial work, I did find a leaking head gasket when I took it apart today...leaker head gasket was an OEM Kohler, as is the one that I put on today. It has been few enough hours since I last had the head off, that all the deposits on the piston wiped off with a shop rag. no carb cleaner or scraper needed..... the exh valve is certainly tighter in its guide than the original was, can feel a big difference between new and old. of all my machines, this one is the one I tend to use the least. usually as a tug for my popup or my utility trailer or the lawn sweeper, is about it.
been debating on whether to put the snow blade back on this one, as I had it set up last year... still has its WW fluid-loaded tires on it but I pulled the chains and the snow blade, when I took it to be my butt buggy at a local threshermens show over this past July 4th weekend.... but without it, I still have the 48" 2 stage snow blower on another Ariens (GT19 with power steering) plus the Deere 828D and MTD 2 cycle "freebie" walk behinds running and ready for action sitting here..... I can't use all of them at once by myself, my wife hasn't ever (and won't) run a snow blower, and my son bought a house of his own, so I don't really need it this year..... might toss the blade on it and send it or the Deere (not sure which) home with the kid.....
