Finally had some success today. Put the aftermarket carb back on the Polaris Ranger this morning. Had a plan in mind on how I was going to attack this to get the carb adjusted for idle & idle+running. I had to make a real stubby small blade screwdriver to start with. took a pocket screwdriver and cut the blade off about an inch long. Then cut about 1/2" off the top of the handle, drill an under size hole in the end. Cut a notch in the round end of the blade with a cold chisel to give it some grip. Put the two pieces in a vise and forced the blade into the handle. Ended up with a screwdriver about 1-1/4" long. Slide a piece of plastic tubing over the blade and trimmed the wide sides down to center the blade up in the port of the pilot screw. Put the carb on, hooked it all up and started it up. Fired right off and kept it running while reaching under the carb with one finger on each hand and adjusted the idle screw up. Several start, stop, adjust pilot, lower idle speed, repeat sequences and finally got it set to where it would idle slow enough and smooth enough to stay running and still shift into gear. This has a clutch/belt set up very similar to what the snowmobiles have/had. Very rewarding to finally get that thing running decent.
Picked up the new custom built metal lathe spindle for my metal lathe. Due to wear in mating parts went with an oversize straight key rather than a woodruff key. Had to shorten the key a bit to get it in place in tight space. The the adjustable bearing had oil on the outside and and wanted to turn in the casting of the lathe. Had to take it all apart, clean up the bearing and casting and put it all back together again. Finally got it back together and running nice and smooth with about .001" or run out.
