Solid steel.Ate those dishes plastic
I'm not the first person to do this. I looked at the cost of something used or new like Noel's, just couldn't justify it.
I agree doing with what you have is a satisfying feeling. We had two of those when we first moved here they were plastic. I have another one in my scrap pile about 3’ across that’s metal. I started a tool bar made from 2” square tubing, basically a wide bar that you can attach different tools on by sliding them back and forth. All I have thought about would be 2 or 3 furrow blades for planting, a couple of disc for hilling and a breaker bar. I quit because I seen the type that had two bars that you could spread wider for adjusting. Chieffan posted one he had the other day that I liked that was similar.Solid steel.
I've never in my life seen a plastic parabolic dish for satellite receiver. Plastic would never reflect the signal to the receiver head.I agree doing with what you have is a satisfying feeling. We had two of those when we first moved here they were plastic. I have another one in my scrap pile about 3’ across that’s metal. I started a tool bar made from 2” square tubing, basically a wide bar that you can attach different tools on by sliding them back and forth. All I have thought about would be 2 or 3 furrow blades for planting, a couple of disc for hilling and a breaker bar. I quit because I seen the type that had two bars that you could spread wider for adjusting. Chieffan posted one he had the other day that I liked that was similar.
Since we live in the same region, we watered the gardens as if no rain is coming. Thus your comment being doubtful is spot on.Don't know that it counts as a "tractor" and it certainly ain't one of mine(I don't make near enough to afford it) but I just got the carb back onto a 27hp Kawasucki that's mounted on a Hustler ZTR.
It's a few years old now (looks like around 6-7) but it's been sitting, the hour meter shows a whole 11 hours on it from new
John, the property owner who's barn I store my junk in, owns the Hustler. Nice 72" cut. He bought it a few years ago (I think it might have even been a demo or a left over past year model as I'm sure he got it new and not as far back as 16/ which if I'm interpreting the numbers right, when it was made.
He bought it, used it a few times then went into a nursing home and then to an assisted living type place and there it sat
I tried to get it running a couple of months ago, aired up the tires, put a new battery in, and couldnt get t it started. I'd dribble a little gas in the carb throat and it would run til that was spent and no more.
Kawasucki wants you to buy a whole new carb which on this one is $500. I don't see John very often and I'm the one who's been mowing his place for a good many years now, but I sure don't have it.
For 3 "o" rings, 3 paper gaskets and another weird o ring that is in the shape of a small butterfly. I paid $28 for that. And what few parts they DO make available for a carb overhaul have to be bought separately, and are obnoxiously priced.
For instance if I'd have wanted a float that is plastic and $41. Just an inlet needle (no seat) is $21. And everything is "special order" which takes 2 weeks to get. A lot to be expected to spend to maintain one of their pieces of crap, and in this case especially one with 11 total hours on since new....
I then mowed with it a few hours, admittedly mowed 2 areas probably more suitable to a bush hog than a ZTR mower, but it got thru it. I had to make 2-3 passes with the deck all the way up and 1/2 swipes at a time the first pass, then 2 passes after that at the 3" he had the "low" setting set to....
The rest of the yard I literally flew thru, besides those 2 areas which hadn't been mowed. Since late last summer/ early last fall. Definitely hadn't been mowed with the rest of the yard that had been mowed this year. I have my doubts that it will happen but we're supposed to get a good rain tonight tomorrow and Monday. IF we do I'm glad I got thru that waist high stuff now while it turned into dust as it was mowed rather than once it gets damp/wet to where it would have done nothing but clog the deck....the worst part of mowing out there today was that when I did the front yard Id mow down, turn around and eat the swarm of dust still hanging from my last swipe as I went back up the other way.
I have my doubts that it will happen but we're supposed to get a good rain tonight tomorrow and Monday...."
Because you haven’t seen one doesn’t mean they don’t exist. If you’ll pay the shipping I’ll send you two of them.I've never in my life seen a plastic parabolic dish for satellite receiver. Plastic would never reflect the signal to the signal to the receiver head.
9 days, I haven't mowed in a full month.Mowed with the Craftsman GT5000. Even though the grass is green and we are getting some rain, it's still growing kind of slow. 9 days since the last mow and it still didn't look too bad.
Yep. What he said!9 days, I haven't mowed in a full month.
You probably have never had Kentucky Bluegrass. If the conditions are right you can watch it grow.Have had some rain with another shower this morning. Grass will start to green up again but haven't mowed in over a month. I have never mowed ever 4-5 days. I don't mind mowing but not that often.
Yep. What he said!
Ditto for now but a month or so ago I was mowing every 4-5 days.
