in the garage yesterday to figure out what was causing the variable speed to not work correctly. It would go into the 3-5 range but not in the 1-2 range to park. I ended up pulling everything off including the variable speed control and tower. The only one big issue I found was by the clutch pedal control there is a pin a flat pivot bar hooks onto and it was almost worn all the way through the shaft.
I ended up welding up the shaft and grinding it down round. It should last another 50 years. The tractor is 80% back together, I need to replace the key switch with a new one set up for a Magneto engine. This key switch was never wired correctly to shut off the engine when the key is turned to the off position.Cut grass again. Hard to believe it’s middle of September and my grass is still thick and growing like crazy! It just doesn’t stop
I've mowed twice since mid-June!Grass slowed away down in growing here. Brown spots in the yard. Normally the grass perks back up in September around here, after a hot August. Not this year.
Been a crazy grass cutting year around here. Every cut has been like a spring time cut. I haven’t had one brown patch of grass this year.
jhn9840
John
I never had a “summer” grass all summer. It was always thick and growing fast! I could’ve cut twice a week most of the summer.
Nice job and a nice drivewaySaturday I used my 1450 to cut the backyard. Since I got my 882 and 1440, it hasn’t been getting much use this year. It was my main mowing tractor for the past few years.
View attachment 59123View attachment 59124
I also did some road work with my 882 and 125 where it washed out a few weeks ago. Saturday after I cut grass, I went and dug the good gravel out of the ditch. Yesterday I spread most of it. There’s still a little left that I have to haul further up with the cart to fill ruts.
View attachment 59125View attachment 59126View attachment 59127View attachment 59128View attachment 59129View attachment 59132View attachment 59130View attachment 59131
So why didn't you post the video of you in that ugly tractor, Jim?I cut grass again with Hoopdy at one of the field areas that’s suppose to be slowing down. This is my second cut out there thinking it was going to be last. This area is where I have been trapping coons. I forgot and left the trail cam on and later I brought it in to clear the SD card. I had about 12 videos of mostly deer and rain with a few rabbits. All of sudden I see this old man flying across the field in a what looked like a demolition race, it was me ! I busted out laughing this poor tractor looks worse moving than it does sitting still. I’ve said it before she ain’t pretty but it’s a darn good grass cutter.
I messed up and deleted it without thinking. You all would have loved it.So why didn't you post the video of you in that ugly tractor, Jim?
Nice job on the ramp and a good looking team at work. Just out of curiosity Noel is there a reason you never painted the OSB sheeting on your mini barn. I watch a lot of shows that are in Alaska and other parts of the country North and they never paint it either. Around here it wouldn’t last two years. I built log homes for three years and we used the 3/4” T&G OSB board for the subfloor. We had to literally mop it down with a sealer because most of the houses took close to 6 months or longer to build.MF team out enjoying the day and havin a chat. Hehe
And we repaired the ramp to the mini barn.
