Got a ton of wood pellets into the basement. Can't get to the outside basement door with the big trailer so transfer the bags to the yard wagon 12 -13 at a time. Pulled it with the White 1655. Mrs lifts them over to the sheet of steel roofing to let them slide down the steps where i catch them and stack them. The White is my go to tractor for most anything any more.
Fired up the Bolens 1256 this afternoon. Haden't been run since the the 8th of July. fired and ran in les than a full revolution. Now that is the way I like them. Put the brinly cultivator on and pulled together a bunch of the vines, etc. to a pile in the middle of the garden. Ready for burning - way to wet for plowing but once I get the cover off it will dry faster.
Yesterday I finished the deck for the Case 195 and was able to get it mounted up to the tractor. Today I pulled the mower deck off of my MF10 and mounted up the snowblower just to have it all ready if needed. I also picked up my Kohler K321 from the machine shop, had it bored .020 over and valves done. I will start to put it back together tomorrow. The engine is an extra I have for one of my MF14's. I plan on getting my MF14 I mow with up and running and mow the back yard tomorrow.
Plowed the garden. Was a little wet but turned OK. Darn Giant Foxtail root clumps kept plugging between the coulter and bottom. I should have pulled the coulter off. Got several of the others lined up for winter. The two are under a tarp as I had a leak in the roof above them and not sure I got it fixed. Have 4 more in another building, plus one in the shop and 2 in the garden shed.
View attachment 7245 View attachment 7246
Wish I had a roof over mine!
Set up the GT235 then cleaned up the leaves at mine and the two neighbors houses then hooked up the 30 cart to the 210 and moved some left over mulch. Been meaning to restore that cart but it’s just been coming in to handy helping out with yard work.
