I just realized today that " Winter project " was probably not the best title for this posting.
The temperature is only suppose to be in the mid 40's today and it's a little chilly working out in the garage.
The only heat source that I have out in my garage is a salamander heater and that works alright for warming up the tool room a little because it is only 10 by 20 and is enclosed ( except for the open doorway going into the main garage ).
However, the main garage is open to the roof and the loft with open eves to let the heat out in the supper so it would be a waste of fuel to even try to heat that area.
Soooo .... as the days get colder, I will be inside working in my train room instead of out in the garage.
That said .. I did get some work done on the tractor today.
With the transmission finished, it's time to start working on the frame.
This is what's left of the old frame and it is going to the scrap yard.
The new frame is going to be made out of 1/4 inch thick square channel steel.
With the axle upside down, the two frame rails are blocked up so the wheels are off the ground and the axle is resting on the frame rails.
They are adjusted so they are square and parallel and then they are clamped on both ends so they will stay in that position.
The axle is then moved into position on the frame.
Just to double check the squareness of the axle, I measured from the inside of the frame out to the edge of the front of the wheel and also to the back of the wheel and the distance was different by about 3/8 inch.
I rotated the wheel and it moves in and out by 1/2 inch and the other wheel varies by about 3/4 inch.
Considering how old this tractor is and how much abuse it has obviously had, I don't think that is all that bad.
The axle is clamped in place and the mounting holes marked with a center punch.
Originally, the axle and the transmission were bolted solid to the frame.
Because the wheels are chain driven, I want to have a little adjustment between the axle and the transmission.
The frame rail is put up on the drill press and the first hole is drilled on the center punch mark.
Then another hole is drilled two inches from the first hole.
These are clearance holes so when I mill the slot, the center of the end mill doesn't have to cut any metal when I crank it down into the metal.
The frame rail is then put on the mill and the first cuts are made and the dial readings are marked down.
Starting with ' 0 ' on the dial at the left hole, 20 turns of the crank handle on the table to ' 0 ' reading is two inches of travel.
Because of the slack in the thread, I have to turn the dial past ' 0 ' to ' 3 ' on the dial when coming back to be in the same place where I started.
The first notch is finished.
