You're going to make er last another 70 years...Stripped the inside of the flywheel cover and treated it with Ospho. Stuck it under the heat lamp for 10 minutes to dry it after treatment.
Normally when I treat metal with Ospho I have to wait until the next day for it to dry so I can prime. This heat lamp dries it in about 10 to 15 minutes. I'm planning on painting the fenders and flywheel cover first and then do the hood and grille which will be green and yellow. That is where the heat lamp will really help out curing the green paint so I can paint the yellow without getting a wrinkle finish. In the past I have had to wait over a week in colder weather before I could be confident in not having trouble.Nice catch on that rust, CJet! Between your wood stove and the infra-red lights I bet you have no problem drying the filler, primer and paint! Nice thing about doing panels rather than an entire tractor or vehicle!
Do you spray or brush the Ospho on ?Normally when I treat metal with Ospho I have to wait until the next day for it to dry so I can prime. This heat lamp dries it in about 10 to 15 minutes. I'm planning on painting the fenders and flywheel cover first and then do the hood and grille which will be green and yellow. That is where the heat lamp will really help out curing the green paint so I can paint the yellow without getting a wrinkle finish. In the past I have had to wait over a week in colder weather before I could be confident in not having trouble.
Never use it but reading about I guess you can do either ?
JD had 2 Greens, The Classic Green for the 2 cylinder tractors and then the AG and Turf green for everything else. Now when you bring in other brands the variations are infinite. What you see in my pics is the Classic green but the pics make it looked washed out. If you put the 2 JD greens side by side they are very similar but still different. Some JD guys say they can't see the difference but I haven't compared it for probably 20 years.How many different shades of green did JD use ?
Or should I say did they use more than one shade ?
Classic is a shade or two darker than Ag and turf.JD had 2 Greens, The Classic Green for the 2 cylinder tractors and then the AG and Turf green for everything else. Now when you bring in other brands the variations are infinite. What you see in my pics is the Classic green but the pics make it looked washed out. If you put the 2 JD greens side by side they are very similar but still different. Some JD guys say they can't see the difference but I haven't compared it for probably 20 years.
Not seeing much overspray...Shot some epoxy primer on the hood.
