That is the one.Was that the unit from Barto?
Hopefully the paint has plenty of cure time!Hot out today, be glad when it cools down a bit...I did do something though, put some paint on my snow plow blade anf snow blower chute. Makes the snow slide off better....Not that I am wanting an early winter either.
Will the fuel line hold moisture and cause rust? Don
I know how that goes. Put a hanger bearing in truck. Got it all assembled then noticed THE spacer bearing in old unitThird time the center spindle on the Cub Cadet 50C deck locked up. Do not have a good parts manual for this deck so have to go by Parts Tree picture, which isn't all that good. Burnt up another top bearing after about 2 hours run time. After a couple hours of searching I found a deck operators manual that mentioned a bearing spacer. That part was not there when I took it apart. Apparently it fell out without my knowing it the first time I replaced the bearings. Mrs found it laying on the ground right where I had the deck hanging to work on it. She laid it on the work bench. Tore it all apart, cleaned it up good, put it back together with hand packed bearings and the spacer in place this time. Made sure the spindle was pumped full of grease before the blades went on. Worked a bunch better now that it is together right. Couple hours mowing tomorow and will have it done once again.
As far as Cub parts listing, I use these folks:Third time the center spindle on the Cub Cadet 50C deck locked up. Do not have a good parts manual for this deck so have to go by Parts Tree picture, which isn't all that good. Burnt up another top bearing after about 2 hours run time. After a couple hours of searching I found a deck operators manual that mentioned a bearing spacer. That part was not there when I took it apart. Apparently it fell out without my knowing it the first time I replaced the bearings. Mrs found it laying on the ground right where I had the deck hanging to work on it. She laid it on the work bench. Tore it all apart, cleaned it up good, put it back together with hand packed bearings and the spacer in place this time. Made sure the spindle was pumped full of grease before the blades went on. Worked a bunch better now that it is together right. Couple hours mowing tomorow and will have it done once again.
