Got the breaker box out of the old woodshop/trailer this morning. Fencing pinchers make short work of the wires right at the box. Cleaned up and ready to go in the container woodshop. Few pictures:
View attachment 98742 View attachment 98743
Storm end of a 14X70 mobile home/ trailer house I used as a wood shop for several years. Was 3 windows where that blue tarp is.
View attachment 98744 View attachment 98745
Walk in door installed in the side of the container. 4 of those angle iron brackets on each side of the door frame to hold it in place. Once I get power there will tack weld each one to the container wall. Door and jamb can be replaced in the future if need be.
View attachment 98746 View attachment 98747
Inside of the container serving as my wood shop down the road. That book case has all adjustable shelves, everything is 3/4" Oak plywood, 7' tall and 8' long. Had to cut it in two to get it in the old shop. Glued it back together and it stayed solid. Took it out through that opening covered with the blue tarp. Window in the East end came from the one bathroom in the old shop. Put in the same as the door but lighter brackets. So far no leaks.
Remains of the inside of the old shop. So far this part is dry except for one leak that white trash can is sitting. That tall army green file cabinet came from the clerk of courts office about 30 years ago. 1" x14" drawers for all the different forms they had to have. Now it is on on computer. Would sure like to give that to some sucker so I would not have to mess with it. That this is mighty heavy. Will probably be the last to go with a chain around it and drag it out onto the ground where the loader can get at it. There are 3 of those smaller power stations for the various tools. All are Shopsmith and will but use on the 510 Shopsmith now. 11" band saw, 14" scroll saw, 6" jointer, Oscillating drum sander, dust collector and probably some others I forgot about. Next step is power to the shop, then I can get it painted yet this fall. The other container has power to it. This used to house my HO model railroad before the wood shop that is why you see the clouds painted on the wall.
