Thanks for that drawing, Bill! I'm still high bidder on the plow. Looks like someone may want the bar clamps worse than I do. Don't know if I will bid on them anymore. Think I will have to bid 20 bucks to stay on top. I also put 5 bucks on a 8' tall decorative windmill similar to the ones Gary and Lowell have worked on recently. It's bent up but looks to be complete.
On another note, you guessed it---I hauled home more junk from the scrap trailer at work today---LOL!
Wrought iron stair way handrails, a spare well pump and some miscellaneous steel for building stuff.
Oh the big white box is a metal cabinet with shelves in it. I've got a wooden one in the shop that this metal one will eventually replace.
Plan on painting it first.
Then since it got a little bit above freezing without gale force wind, I heated up the shop for while and did a little bit of tinkering.
I took a Scotchbrite to that rear pto cover for the MF1450, cleaned and painted it, inside and out.
Then I cleaned the Carb from the old go-kart engine. Parts aren't here yet for the rebuild.
And lastly I took all the fittings off the sandblaster tank, cleaned and put new teflon tape on them. Reassembled and pressured it up. No leaks now.
