Every time I came across those you described, they went in the garbage, Chris! I started collecting these things back in the 1980's for ballast on go-karts---LOL! Time to use them for something.At least you ended up with the good weights and not those plastic concrete things that were given to me. Next time I fill in the burn pit I think they are all going in there.
I had a barrel full of bed rails at one time mostly from people just tossing them out. I’ve used them a lot over the years.How about an old bed rail? Those things a usually real stout iron to cut or drill. I grab every one I can get hold of at auctions.
There are scrapyards around here, but none of them will sell scrap to the public! They buy it, crush it up and ship it out. There are two new steel companies, one I won't deal with and the other is expensive but very good service.Nice stack of old weights Doug. Looks like it’s going to work out good. I have a scrap yard about a half hour away I like a lot. I also have a welding shop about 15 minutes away that I can buy new steel from reasonably mostly off falls. Like you I still hate to buy it.
Any and all suggestions are welcome Chris, including yours---LOL! The smallest channel I have is 4"x1-1/2" and that would be too bulky. Now if I split a piece of that channel, it may be about right though! Good thought!If I can make a suggest? Going from your photos is there a chance you'd have some 2" or 3" channel iron to use in place of the strap. It would be stronger and might keep you from buying metal.
You have me thinking about that now, Roger! I do have a lot of bed rail around here. That stuff can be pretty hard to drill but I have heated up spots before where I needed to drill to take the temper out of that spot and it seems to help. Seems to weld fine though.I had a barrel full of bed rails at one time mostly from people just tossing them out. I’ve used them a lot over the years.
Still have 27.5#. 4-4.4# and a couple of mismatched ones. I can't see a good way to mount them on the front wheels. I won't put fluid in these old crappy tires. Surprisingly, they do hold air at least! If I get new ones, definitely will fluid fill! I think the tires will crumble if I try to break the bead or try to squeeze them to suck in fluid. Thanks for the help, Noel!Lookin good Doug. If more weight is needed, do you have any barbell weights that would fit the front wheels. And load the front tires with fluid. Might gain 20 lbs doing that.
That may be what happens still Chris---LOL! May not have enough weight on the front to stop wheelies anyway! This tractor is by far the fastest one I have! It really gets a little scary, full throttle, high range and full hydro! Had to run it a few laps around the old go-kart track when I got it running!If you’re worried about the strength of the bracket just do a few wheelies. If it holds up to that you’re good to go
No holes in the front wheels, Noel. The tires have tubes but they are so old and hard I don't think the tubes would survive loading and putting in new tubes will destroy the tires. Maybe you have a method how to fill tires/tubes with fluid that can vent the air out while filling without squeezing them down? I don't want to put the money out for new tires yet. I have a set of almost new rears for the MF1450, but no extra 8" rim tires around here. I need front tires for that JD110 same size as the 1450 but don't want to buy any until I know it will run!Should be holes in the wheels ??? If there is could you drill the weights to match those holes.
I’d be putting tubes in if I was going to load them Doug. That’s just me. Every body has their opinion.
