Well, not good news. I got all the zirks I could find to take grease, but that is about it for the good.
Good was the right spring pin freed up with some persuasion.
Tried the same persuasion with the right one and broke off the roll pin, using a punch at it's base to try to get a little movement. First bad thing.
Put it on the lift and raised it up high enough that I could roll around in a chair to work on it. Having back issues.
View attachment 71045 View attachment 71051
There are at least 2 bad seals. RR axle and the brake shaft. Look at the color of the leak all over the brake drum and band. First hint of worse news.
View attachment 71049 View attachment 71046
It sucked to get the fill level and drain plugs broke loose. Ended up clamping vise grips on the square heads and hitting it with a hammer.
Did JD make orange gears?
I didn't think so---LOL! I knew there was big trouble when nothing but water came out of the drain plug. Might have been part dog pi$$!
There was one other GOOD thing that happened today. I'll cover that in the next post.
