Live and learn! I should have tried to find u joints with zirks in the cap ends instead of the center! No way to get a normal coupler on the zirks. I ended up putting the steel line on the gun and using a needle. Even then the needle required a little bend in it to hit the zirk hole square enough to seal on the zirk. Changing the angle of the u joint wouldn't have helped either. The steel line allowed me to push harder than the flex line. It did work and now I know how to do then next time! Finished the oil change and lubed all the front suspension components.
The truck should be good to go for awhile!
