And more junk.
That tire held air overnight but is probably destined to be tubed in the near future.
I took Diana's Murray back to her place today and mowed the small west yard. Seemed to do a good job. Too bad it sits outside. I might go ahead and put the carb kit in it too at some point. The gas could be getting in the oil due to a leaky needle. I shut off the fuel valve and let it run out of gas. Going to cut off a few tree limbs for her too, Maybe Friday. Sounds like rain tomorrow.
Came back to the shop and lowered the lift to work on the MF1450. Some of you may remember that the machinist at my former workplace built a solid driveshaft to replace the wobbly Lovejoy coupling that was on it.
I need to do some dirtwork in the front yard where the waterline was dug in last winter, and the three point will make it easier. Went in pretty well but still couldn't line up a couple of bolt holes. It dawned on me to look at the carrier bearing mount. Sure enough it is slotted. I loosened it up and it moved into place on it's own. of course tightening the last bolt the ratchet slipped and I sliced my left arm! This old pile of $h!t has more jagged metal on it than any tractor I have ever worked on! Seems like every time I work on it I draw blood---LOL! Decided that was enough for today. Maybe will start it tomorrow and see if there is less vibration.
I'm thinking about drilling a zirk into that shaft to grease the splines from the inside out. Will have to build a shield over it as grease will sling right up into my face! Can't afford to buy a used original plastic tunnel cover. They sell at ridiculous prices on epay. Probably have to do it like the dash. I had to build it out of 1/8" aluminum.
hopefully more tomorrow.
Use a piece old old guttering for the shaft cover. Older round or the new K type will work. Or even the round down spout split. Piece of 3" plastic water line is another way out. I split 2" and REC slides it over the power lines for me where they run through the trees at the house.
Those are good ideas, Rog. Thank you! Don't have any old gutter or downspout around here. I do have some 3" pvc. No good mounting provisions though. The mounts are there to cover the hole where the original plastic cover used to be and I have plenty of 1/8" aluminum. Hauled home old signs from scrap at work when they changed them all. Could even use sheet metal I suppose.
Had doc appt this morning and some in the house chores to do when I got home. Had to go to the $h!t plant to buy some eggs from a former co worker at noon. Have to catch up on the plant news of course!
Got home had lunch and headed to the shop to tackle the other old washing machine.
Still don't have a good battery in the MF1450 so I gave it a boost to go out and get the other machine. It fell off the drag a couple times. I should have strapped it down. The leg with the wringer and agitator mechanism box on it is really heavy. I should have backed in but decided I should use the bridge crane to lift that heavy piece of crap around. Was pretty easy to drag. Trying to save wear and tear on my back.
Used the hoist to turn it upright after getting the guts pulled out of it. Lots of broken bolts but some loosened just fine. Some of the cast iron brackets were broken too an fell off. Took the lid off too. Had to drill new holes in the tub to support that wringer post. Bolts were gone and wouldn't line back up to the original holes, even beating and prying. One of the holes had corroded out to about an inch or bigger anyway.
Found a pot that may fit that square hole but was tired and have a damm sore toe and back for some reason. Will have to set it on paver pieces and level too. Round pot but can't do much about that!
Maybe will get that done tomorrow and possibly mow.
Carolyn has 4 or5 set of wash tubs, double tub type and a single. I cut 2 X 6 treated into 6' squares. Then drill a 1.5" hole about 3/4 inch deep in the center. We put one of these under each leg of the tubs. Once set they stay put in the wind or even bumped with a mower deck.
Don't be so hard on yourself. Let me do the kicking. :eek:
Was the car a 2dr or 4dr? Did you happen to ask the guy what he would want for the DeSoto outright?
You will need a 400 mile long leg to do the kicking but I feel it already, Chris---LOL! It was a 2dr sedan. Didn't discuss any money. He seemed to be in a hurry. Maybe he will be at the Fleet Farm car show Saturday.
That treated 2x6 probably works better than what I did Rog. The wheels are all froze up on these things but being in a hole like you did would be much better. Will probably do something like that when this area gets the pea gravel widened out. Probably won't be this year.
Had some non tractor or yard related stuff to do for awhile today for the racing Hall of Fame group I am a member of. Got to the shop and turned the MF1450 around after lifting the aluminum tub machine up with the bridge crane hoist.
Used my head for more than a hat rack this time and strapped it to the drag.
Got it unloaded and walked it to the location it goes at. I had already smoothed the dirt and gravel out. Lifted and pushed pieces of pavers under the legs. Found a plastic pot I was able to force into it. Had to scoop dirt and dump dirt out of it into the yard trailer to deform it enough to shove in the square hole. Good thing as it looks like it was mostly clay rather than good dirt anyway.
The yellow looking dirt is the clay.
Pulled the trailer around on the concrete and shoveled the dirt from the rotted wooden barrel halves into it. Much better looking dirt.
Loaded both pots.
Took what was left and dumped in the dirt pile out front that will be spread and used to fill some holes around the yard later.
The redneck tube patch on the trailer is still holding---LOL! Will get a real patch kit at Fleet Farm Saturday.
Had more Hall of Fame stuff to do for awhile today. The inductees for this year will be announced on FB on Father's Day so we are all gathering info for that.
Took this 70 year old junker to the car wash and sprayed it off.
Brought it in the shop and started cleaning the interior up. Had sprayed tire cleaner on it before bringing it in. It's got garbage carpet waiting to be ripped out and for me to install the new floormat. Will put new door gaskets on at the same time. Just need a few days in a row to do that!
Dash, gauges, and steering wheel are the nicest stuff on this truck---LOL! Cleaned the windows inside and out too. Need to replace that right wing window too. All the other door glass has been replaced.
Rebuilt that stuff around 12-13 years ago. All the brakes, lines and master cylinder were new in 2011. Only about 8-10,000 miles on it since then. Figured I better check the brake fluid. Used to be able to use a 7/8" 12 point socket to take that cap off. Stripped the corners off this time. Decided to try a 3/4" crowfoot. Popped it loose right away. I didn't have the crows foot set back when I did all the brake work. Been probably 3 years since I checked the brake fluid! Just looked for leaks at the brakes and master cylinder from beneath. It was full and the fluid looked like new. IMG_2725.jpg
The rubber cap is getting real stiff and hard to pop back into place. A little grease on the lip and it went in nicely.
Just checked fluids, no under hood cleaning which it needs too. All good. Oil change coming sometime this summer too.
Threw a couple of core tractor batteries in the box to take to Fleet Farm tomorrow.
Good as it gets!
Just got to thinking---this thing is 70, the MF8E is 60 and the MF12G is 50 years old this year!
Been awhile since I seen a engine that you can almost sit next to and work on.
There's a of room alright, but I'm still way to fat to fit, Jake---LOL!
That old washer motor would make a real nice bench top polisher! 1750 RPM isn't too fast. Mount the wheel directly on the shaft.
That's a good idea, Aaron! Might have to see if it runs to do that!
Even as a. Ford guy, I love that Ole GMC!
Glad you like it Daniel!
that thing was loaded for a truck back then Doug....it had a clock....!
What's that thing mounted lower middle of the dash ?
I got the clock in a horse trade later, Bill. Definitely was a basic truck originally. It don't work so it is just set at 5 o'clock. Goes with the Alan Jackson song, "It's 5 o'clock Somewhere"!
That thing is a kleenex dispenser. Got that in another trade one time.
Had a Chevy logo on it original. I had to remove that and make a little GMC logo. It swings out to get a tissue. Old pics but there is a box of kleenex in it now.
The old farm truck had to do a little work today. Hauled tractor batteries, seed a seed spreader and hay bales---LOL!
Just got a couple of the cheapest $29.95 230CCA batteries. Actually got a 10% discount on all of that stuff for having Fleet Farm discount, so there was $2.90 knocked off of that too! Had a couple of cores with me. Think I might go to them for more stuff since there is no games in the rewards program.
Got home from running around in town, grabbed a bite to eat then put a new battery in the MF1450. I forgot to spray some corrosion protector on the posts and mount. Will do that tomorrow.
Ran it in the shop and built some mounts on the drag to bolt the scarifier to. My first idea of making it swivel and pinning it sounded like way too much work. Went with the KISS method. Cut and drilled a couple of 1/4" plates. Used 9/16" bolts since I have some on hand. 7/8" nut and head.
Ground off the galvanizing obviously, and welded them on. Squirted some grey primer on them and put it back on the tractor.
The drag, materials for the 3-point t-bar and scarifier and even those tools except the socket came from the scrap trailer at work, to keep this pertaining to this junk thread---LOL!
Got the well going today even though it was 105F!
Had to change out the hydrant head inside the shop first which was a battle. Temp was ok but still worked up a sweat! First had to move junk to even get to it! Forgot to take a before pic. Strapped the sink to a dolly cart and took it out to the main bay under the lift.
Going to give it a good cleaning and mount casters on it. Don't know how yet until I turn it over.
Still more junk to move.
Space where the sink was and a 250 inline 6 Chevy. The engine is on an old shopping cart base that has to mounts welded to it so it rolls easy.
Had to move that shelf too but no pics. Just swung it out to give room. Of course after 34 years that thing wasn't going to unscrew with just me. I didn't want to disturb the underground connection so a cutoff wheel, chisel and hammer removed it. The cut up old one and the new one.
This is why this work was needed. My fault of course but got it swapped out eventually.
Had to hold up the internal pipe to get the new one started. Adjusted the new one like the old one and put it together. Didn't know about leaks yet since the pump needed to go out to the well.
Primed it and plugged it in. Have water to the shop, but not the house to the sillcock the plumber installed last December when we switched to the water system. I was too tired to crawl under the house and see if there is a shutoff valve where it comes from the well. Probably is and the plumber forgot to open it. That was enough for today.
No leaks in here.
