Worse than that here! May see that stupid white crap!Looks chilly next week, but was a very enjoyable weekend. Still have the doors open.
Mig welders are good for thin sheet metal. Gotta use the small wire though.Worked on trying to revive the headlight lens yesterday, L side came out ok, R side was a fail, I have added this to the next parts list.
Got up this morning feeling like the weather, sore throat, damp, and chilly. Not a pill or drop of “make me feel better” in the house, so off to Wal-Mart for some Advil, the innerweb says it’s the Best for Fever, Aches, and Sore Throat. While there I picked up a can of Forest green to see how well the color match might be.
Looks like Ill need to learn some body work skills before I paint this.
I have been looking at some welder reviews so to decide if I want to get one. “This old Tony” reviewed one for $60.00 that caught my interest. Not sure stick welding would work well on the thin tin cracks on the fender pan. I think TIG may be better, just no skills yet.
And work the trigger like you're making small tacks but making a continuous weld.Mig welders are good for thin sheet metal. Gotta use the small wire though.
Argon/CO2 mix. You may get some BB's with it, but not nearly what the Flux-Core would have!Lots to learn, what gas would be used with this one?
Klutch MIG 140i Flux-Core/MIG Welder Inverter, 120V, 30140 Amp Output | Northern Tool
This Klutch® MIG 140i is an inverter-powered, wire-feed welder for flux core and MIG welding. The inverter-based s...www.northerntool.com
One thing to consider with a lathe is that without tooling it is a boat anchor. that one appears to have a 3 jaw chuck and a two way tool post. next you need a four jaw and a quick change tool post, center rest, traveling center rest. You can also use a drill chuck for the tail stock. center drills are a must. Parting tool and holder. Micrometers, calipers, feeler cadge. dial indicator. Not trying to discourage you. Just letting you know they can become another addiction. And then you find you need a mill. DonI've watched enough welding videos to know I would probally get more use from a welder than something like this, but I think a metal lathe would be nice too. Something else to look out for used.
Precision Lathe PD 250/E
For face, longitudinal and taper turning, thread-cutting. For machining steel, brass, aluminium and plastic. Mounting flange for fastening the mill/drill head PF 230. Centre distance 250mm (10"). Swing 70mm (2 3/4"). Height over cross slide 43mm (1 11/16").NO 34 002 See full description...proxxon-us-shop.com
