Its just about ready for work. I'm going to pull the front wheels off, break them down, and paint the front rims. The front rims have some damage where the bead areas are bent probably from hitting a sharp edge of concrete when the loader bucket was full. Should be fairly easy to straighten up. I also have new bearings and seals for the front hubs that I will throw in at the same time. I ordered a new steering wheel and front main seal which is leaking a little. I'm sure as I run it, I will find more leaky seals.Looks good cjetread to put it to work?
I can still handle mounting those weights if I have too, but I usually feel it for the next week. Better with 2 people or a piece of equipment to do the lifting.New shoes gook good on there, and those finger pinching full weights.
Loader with a bale spear but still a 2 man operation to be safe.I can still handle mounting those weights if I have too, but I usually feel it for the next week. Better with 2 people or a piece of equipment to do the lifting.
Getting the rims all painted up ,won't be long before you're squirting some red paint it...Its just about ready for work. I'm going to pull the front wheels off, break them down, and paint the front rims. The front rims have some damage where the bead areas are bent probably from hitting a sharp edge of concrete when the loader bucket was full. Should be fairly easy to straighten up. I also have new bearings and seals for the front hubs that I will throw in at the same time. I ordered a new steering wheel and front main seal which is leaking a little. I'm sure as I run it, I will find more leaky seals.
Might be a while for this one. I have several others waiting for paint but this one might be able to cut in line. I have to refill the tractor fund also in order to afford the paint.Getting the rims all painted up, won't be long before you're squirting some red paint it...![]()
I got ya..bet those tires were enough for a couple paint jobs..Might be a while for this one. I have several others waiting for paint but this one might be able to cut in line. I have to refill the tractor fund also in order to afford the paint.
Could probably paint about 5-6 tractors for the cost of the tires.I got ya..bet those tires were enough for a couple paint jobs..
Yes but you can move the tires from one tractor to another really hard to do with paintCould probably paint about 5-6 tractors for the cost of the tires.
Many of the paints and primers I use have doubled in the last 2 yrs. I was looking back through some pics and found when we put new tires on the Super C. These are the same tires that I just got for the 230 and IIRC they were around $600-$700 back in 2015. The tires/tubes I just bought were over $1500.00 this go-round. So much for my cheap tractor.You are so right about the cost of paint these days
We don't farm like the old timers that fired the tractor up at the start of the day and drove it until dark. I think the only tires we have replaced are the ones that came on the tractors and failed from weathering and rot. Never wore the tread down to the point that they needed replacing. We have punched some old T-Posts thru some front tires that needed replacing.Real good chance you will never have to put another pair on it again.
