Without power steering the front lug tires will be harder to make turns with the bucket full or empty.
Mike
Very detailed progress
I use the ratchet to seat the tires. Wow, can they jump when the tire is filled and releasing the strap. Sliced a finger a few times. Yup, I am a hard learner, takes a few lessons to sink in.
Nice progress.
How does that larger battery work on your Ryobi? I have the std batteries, they don't seem to last super long in my grinder or circular saw.
The k46 is "maintenance free" until the oil breaks down and the unit doesnt work anymore. But by then it's usually too late to save it.
The k58 john deere uses in there upper end x300 line is recommended 50 hours first change then 200 hours after that. Same for the k72. I plan on changing mine in my k72 at the beginning of every grass cutting season.
Service that thing and it will last a long time!
Worth every penny and thank you.
I tend to try and see what they will do just to know. For an example, the 15ga finish nailer with the small battery put down approx 70 nails, not terrible, what was, is the lack of power after about 40 nails, they would fail to go all the way in. I put that in the it-can-be-done-in-a-pinch-if-that's-all-you-got. The 4Ah put down 280+ nails before it started to fail.
I don't have the saw or grinder yet so I can't give you apples to apples comparison but,
The little handheld flashlight that is 180 lumen (I think), the small battery lasted 10 straight hours, the 4Ah lasted over 24 straight hours. I can't be specific because I lost track of the time so I have to do it again, but I did check after 24 hrs so I have that.
Where I noticed the difference in power was with the hammer drill (my first purchase) the regular batteries were ok but I was changing them frequently while working outside. I made the buy on the 4Ah and I was using it all day with out changing batteries. I know that is very subjective, but you have me curious now, I may try an idea with the drill all out on high with no load and see how long it lasts. I have been happy with the tools but I've only had them a year and that may not be long enough to really know how well they will hold up, yet.
How long have you been using your Ryobi? how well does that saw work?
I got the kit for Christmas 3 yrs ago, maybe 4. I'm not sure if it's the batteries or the saw, but the saw quits running if it gets any type of bind on it. I notice my angle grinder and sawzall will do the same sp probably battery. We have a tool outlet store, I can get one of those larger batteries for reasonable so may try it.
I've never owned a ryobi product. I've had a lot of tools though. Best bang for your dollar is the craftsman 19.2 c3 stuff. I've had excellent luck with them.
