Sounds like it is averaging about two hours per gallon, sounds pretty efficient to me.Got the rims back. Very heavy, about to go blow out the shed drive and paths to check it out.
Also refueled for the first time. Just over 1/4 tank left, took 4.5 gallons to fill. It was filled with 1.6 hours on it, it now has 11.1 on it.
View attachment 34171View attachment 34172
Tractor needs serious work, clutch needs rebuilt, crank seals are shot. I had to adjust the timing, the valves, carburetor and clean the shut off valve on the fuel tank, and change the oil and filter. Oil was almost as thick and black as the tar they spray on road base before paving. . Looks like they just drug it out of a barn and threw new rubber on it. They also had me put a chrome straight pipe on the exhaustThe flywheel has loosened up. There are two bolt inside of fly wheel. On hub that hold flywheel to splinded shalf. loosen them up drive on to get 15 thousand clearance tight bolt as tight as you can.
thanks Bill
Fronts are 4.80x12 on solid style trailer rims, since I couldn't find any Cub rims at a decent price.CRF6179, what size are the front and rear tires. She looks good. Be nice when painted up.
I have just been adding pictures to this thread.That's a great creation Rick! If you had a build thread going, I'm sorry I missed it!
I would find that very interesting, Rick!I have just been adding pictures to this thread.
I could possibly start a thread and put in all the pics and info in chronologic order.
