Sounds like a relaxing but productive trip, Dodge!
We had a lot of errands to do in town but while my wife was doing some paperwork this morning, I did get the deck pulled from the MF12G. The pin has let go from the weld underneath so the hole didn't go all the way through. I punched and drilled it out, leaving a little shoulder so the pin wouldn't fall through.
Then a magnet was used to hold it square one way put a couple of welds on it then moved the magnet 90* and did the same thing. Found a spacer washer with a big enough hole to clear the welds and still space the idler bracket up the right amount.
Flipped the deck over, cleaned for welding and hopefully the weld actually got penetration on the pin too.
After we got back home late afternoon, Put the idler and belt on with a little grease on the pin, and mounted the deck back on the tractor. Ready to mow once again.
I did fire up the Bolens/MTD LT up and made a few passes around the abandon acre east of us, front half, but I did something wrong installing the variable speed belts or left something loose. Clutch works fine but it is stuck in a slow speed gear and won't shift up on the dash speed lever. It drove smooth but got to figure this mess out now! Hope I can get Thursday and Friday off.
