I finally made it out to the barn today to get my snow blower tractor. My son had my New Holland at his house, to mow his acre and 1/4, (but no more use for it, since he got the Kubota with the bigger deck and the bucket. The NH, and an old Dynamark 8/36 that has no deck (good "butt buggy"/sprayer tow machine) have been sitting on my trailer behind his house, since about Oct. he needed them outta the garage. I grabbed the trailer, and we went out and played "musical tractors" Started a couple, pushed a couple by hand, played "musical battery" between the ones that started, and ones that were missing batteries.
1) the New Holland on the trailer, and 2) the Ariens GT19 with the mounted blower. The GT19 fired right up, has not been touched since about last March. I put the battery from the barn owner's Cub 1200 in, that had fired right up, into the GT19 after letting the 1200 run and warm up, shut the gas off ,and let it run dry again. The GT19 had no battery in, I probably robbed that one for one of the barn owner's Cubs last spring, for mowing duty.
The NH was last run in Oct., Nick had its battery out on his bench, had it on trickle charge a couple weeks ago, it didn't take the charge. Junk. good for core. Took the battery out of barn owner's Cub 1250, it cranked but slow in the Cub.... something in that Cub started setting its smoke leak out. Wound up being the ground cable, where it bolts to the frame. disconnected the Dakota from the trailer, turned around so my jumper cables would reach the NH, (while NH was still on the trailer) and let the truck run and charge the battery, while I moved other things around. We got the NH to run, and left it behind, in the barn. if worst comes to worst, I can go grab the NH and put the snow blade on the front of it, and the weighted tires I have here in the garage....
I need the GT19 here, because of the "Armageddon" they are calling for here starting tomorrow. 6 to 10". hopefully now that its here, the storm will miss us. It would not bother me. I used that tractor alot 2 and 3 years ago, I didn't need it even once here, last winter. But it was here. and ready.
Nick has had my Deere walk behind in his garage since last winter (he wound up never needed it) my daughter in law has been complaining about it "being in the way", we put it out when they had their garage sale, and no interest then. Nick asked me a couple weeks ago on a 40* day with bare ground, if I wanted to sell it. I told him to hold off. nobody would buy with no snow around.
there has been an identical Deere walk behind on CL for 2+ years solid, in town within 5 miles of me/ they are wanting $600 for theirs, even in July....they have not budged in all that time. mine is nicer, cleaner, and has a brand new genuine Tecumseh carb, spec'd for an older HM80 that is adjustable-- I got tired of the Snow King Surge, so I put that new carb on 2 winters ago, and it worked. No more surge, and more power.
I told him not to let it go for less than $400.
Today, I told him to get pix of it and get it listed somewhere (I only have access to CL since I don't do Fakebook) He does better than I do with that sort of thing, at best I get complaints about being too far away.... at worst get offers for 30% of what I am asking, sight unseen. and they want it delivered for that cutthroat price. that gets old. Well, he now lives 20 miles further out in the middle of nowhere/ but doesn't seem to get that "too far to go" complaint from potential buyers. and somehow gets better money for stuff too. I don't get it.
We talked about price to start with on it, and then by the time we got back from the barn that I store my junk in, (26 miles from here, about 8 from his place) he was saying now that he thought it might work better for him than the Kubota and its bucket. so I told him if he wants to use it, then go ahead and use it, and not worry about putting it for sale. If I wasn't "stuck" being the neighborhood snow guy, I would use that, instead of my 48" on the tractor. I wind up doing about 6 other people's driveways around me, every time I do my own.
when I was on my way to Nick's I wasn't sure if I wanted to bring the JD home, or whether I wanted to go get the tractor. If we get Armageddon, I won't have much time for clearing my own driveway (let alone anyone else's) as I will most likely be called into work to keep the state snowplows thawed and out on the roads, so I want "overkill" here for my own drive, at least. Just in case.
I have an old Binks gas powered compressor out there in the barn, just in case I need it while mowing out there..... starts easy in warm weather, I could barely pull it over today at 35*. '72 vintage 8hp Briggs 200000 series cast iron, with manual wrap around pulley on flywheel, for starter. I needed to air up the tires on snowblower tractor, both left sides were low (back was completely flat) so blower wouldn't come off the ground on left corner....makes it a PITA to load onto trailer/ easier when all aired up. I need to find a bigger diameter wrap around starter pulley, maybe like the ones that have the belt driven starter generator size.
Wow, was that old cast iron Briggs stiff and hard to pull the rope over.... took some doing, to coax it to life but I did.... that old boat anchor has been a lifesaver out there in the sticks.... finally got it going, got about 1/2 a tank of air built up, and it ran outta gas..... I put about 1/2 a tank of gas in it and let it run a while. then shut off the valve at the glass bowl, and let it run out in the carb,
Nothing tractor related has happened around here in at least 6 weeks. I made up for that today.
