I hate when this happens but kinda glad it did. You ever get this sinking feeling? when something "fixes" itself without you doing a thing......
This is on John's Cub 1250/ John owns the property and barns I store my junk in, and I have helped mow/ but have taken over all the mowing, since he got holed up in an old folks home/// I think he has more stents now than original veins/arteries.......
We keep it mowed, both to keep the varmints away and also people who pass by, know that someone is around, hopefully they keep their nose out where it don't belong as well..... this will be my 3rd whole season of handling it without any help from him. he has about 3-1/2-4 acres to mow out there. Maybe 5.
He has 3 Cub Cadets. 1-1250 and 2-1200s. My wife likes running the 1250. We use his machines and mine too, to keep the place mowed.
I haven't had a chance to take each machine and go thru them each one by one with a "fine tooth comb" to get rid of their quirks. Between him and I there are no less than 8 GTs out there in the barn. Sometimes we get thru the mow with the 2 machines we 1st jump onto, other times we have to run 4-5 to get thru 1 mow, then the "current issue" gets fixed, when they all need "gone thru" thoroughly 1 at a time and ALL the bugs fixed on each one....
About 4 mowings before the end of the season, John's 1250 abruptly died on my wife. It was smoking hot (not overheating) just hot from having run for about an hour straight. When it died, I checked fuel and oil levels, checked for spark (as I remember it had none-- I've slept since then)
So I gave her the one I was on, and went and got the next machine. We pushed the dead 1250 into the corn crib and forgot about it. I did pull the battery out when I last mowed, in the fall.
Fast forward to 2 weeks ago. I winched it up onto my trailer along with one of my Ariens GT19s that also needed attention. Brought them home. Last week was "shot" with Donna having had to be in hospital "prison" all week..... and its been raining every chance I might have otherwise had, to get after them. I fixed what I had to on the Ariens, and finally today I got after the 1250.... now get this.... I put a fresh battery in, checked the oil, gave it a splash of gas and it STARTED RIGHT UP!!!!! Its been sitting since about September! I KNOW I checked it for fuel 1st thing when it quit! I even sprayed some Gumout in the carb, before we pushed it aside and dead as a doornail. Cranked but no fire.
I hate when a problem "fixes" itself and I don't know what changed............
plan is to bring them home 2 at a time and get them into shape, rather than patch them as they go down "in the field".
I put a new clutch in the one 1200 but didnt realize the shaft must be tweaked (bent slightly) as it shakes like mad. Engine is tight (mount wise) , I did the motor mount mod and everything.... I can see the shaft oscillating as it runs. we didnt get to mow with that one last season. I took it back early to get it outta my way. so I gotta finish that one up.
I want to swap this other motor onto my 129, and hope it don't smoke as bad as the original one does/ found a 127 in the local junkyard with a gray factory replacement K301 for scrap price then brought it home and got it running.....
I have either a M14 Magnum here or the original, freshly rebuilt K321 that it was born with sitting here, that can go onto the New Holland in place of the leaky M12..... so I can fix the leaks.... along with some new bearings in the deck..... and on it goes.
Then to bring home the LT166 Deere and get it up for sale. same with the Husq 21K46 that is now a 17B(riggs)46...... hopefully in the 1st half of the mowing season so those go away easily, with a few $$ in my pocket,,, (those 2, aren't part of the 8 GTs I mentioned earlier)
