Carlise field Trax hd. 120 each on Amazon. John deere dealer told me 500 dollars for the set mounted. I let him know where he can mount them....Nice! Wish those back tires weren't so expensive, like that tread pattern.
Ya, those tires look like they would give good traction. Nice tractor. Must have diff lock ? Power steering. ?
Noel.
I LOOOVVEEE Hydraulics! Nice field.Had grunt out with the tandem disks today. Want to make sure they still spin and grease them. Still work great. But with a manual lift on the tractor, it’s a bit heavy to lift with one arm. And even with two it’s a struggle. Hydraulic lift would be nice.
That is scary ! !Used the YT16H Ford to cut the grass. Had a small thing fix on the deck, so had to lie on ground to do this,,,,,,but then I said. There’s a hoist here,,,, why would I lie on the ground. Hehe. So up ya go tractor. And while up, I cleaned the deck. We have not made a thing for the tractors yet on the hoist which is would be much safer. This was a temporary thing because of this emergency today. Worked great. If your thinking about getting a hoist, do it. So much easier.
Yep, mine has grease fittings also. I took mine apart partially to lube up all the nuts and bolts. I angled the disk more and moved them in closer. I also flipped the rear draw bar around to make the center line up better. One thing that has me puzzled is all the disk blades have three small holes in them around the center axle hole. Makes me wonder if there was a small round weight that could be added to them. Going to try them out this fall in my uncles garden after he gets done picking it clean, hoping they'll do a decent job of cutting up and mixing in the left over plants.Ya JDJake. Almost the same. Other than the weight holders. Grease fittings on the shafts. Mine does. Neat tool to have.
Noel.
SEEN is the key word there Noel.I’m sure you've seen and used scarier things Roger.
They work great. Mine both have the weight brackets on them. I use on single with a sleeve hitch so I can lift at the end of the area for turning w/o tearing up the grass we mow.Here you go,
