If it ain’t one thing, it’s two things. A saying around here. Hehe.
Let's go with 3 things now Noel!Yep, one step forward and two steps back.
Those Viper PVC tracks are some of the best custom tracks made, Chris! Never seen a 3 lane though. A guy down the street has a Viper.Here you go Doug!
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
And all this work just to make it stop...Let's go with 3 things now Noel!
And now it's 3 steps back Chris!
The brake pucks Rick sent got here today. Managed to remove the rear PTO stuff without having to disconnect the hydraulic lines. Had to drop the 3 point chassis mounts so all that work did clear enough out of the way to install the transaxle dipstick tube. Went ahead and cleaned it up and painted it. I had bead blasted it when I was still working so it needed some paint.
View attachment 74897 View attachment 74898
View attachment 74899 View attachment 74900
I made an attempt at test fitting everything before I JB Weld a brake puck into the transaxle. Nope! Not gonna come close to fiting in there with the puck thickness. I pulled the left side transaxle bolts to spread the chassis with a pickle fork.
View attachment 74903 View attachment 74904
Nope, no way it's gonna fit yet. Looks like I need to sand the pucks down quite a ways even if the transaxle was completely out of the frame, that's all the further the frame rail can spread as the 3 point hydraulic cylinder has a welded in crossmember connecting both sides.
View attachment 74905 View attachment 74906
That's enough for today. Gonna have a beer!
That's when brake shoes were really " brake shoes"..Fred Flintstone brakes would work. Hehe.
Tractor Data says it's a Sunstrand Series 15-HT90, Noel. I will probably have a couple more beverages tonight too---LOL! Keep reading.She’s tight quarters there Doug. What model is the rear end. Sorta looks like what’s in my LGT 165 Ford. But it has a brake band.
I’d say have more than one refreshment Doug.
Yup we are pussies today, Bill---LOL! Then becoming a geezer on top of that---That's when brake shoes were really " brake shoes"..
Well come to think of it they used their bare feet...
God we're pussies today..
Hope you get that pucker..First the caliper and rotor got bolted in to see how much room there is for brake pads and the backing plate. Had to use a snap gauge. 3/4 inch.
View attachment 74953 View attachment 74954
The pucks and the backing plate measure a fat 1".
View attachment 74944 View attachment 74945
That figures out to a fat 5/16" thickness for the pads. Then I had brilliant idea about cutting them---LOL!
I haven't used this old Demel scroll saw for 25 years probably but was hoping it would work to slice these things. Set it on the lift.
Cleaned it up and plugged it in. Still ran fine! Added some better light and set up a guide.
View attachment 74947 View attachment 74948
Made an attempt to cut. No go. After a couple minutes it made a small slice.
View attachment 74949 View attachment 74951
The blade seems ok as it cut into a 2x4 quite easily after trying to cut a puck. Big difference between brake material and a 2x4---LOL!
All I could think of was something that rhymes with "puck"---LOL! I think that scoring around the whole puck may give me an accurate line to use the HF bench top belt sander. Might "rough" it in on the side of a chop saw blade, then finish with the belt sander.
Won't be able to work on it tomorrow. Got other stuff going on all day and evening tomorrow so won't be back on until Sunday.
Thanks to Doug I believe "Puck" will be a universally used word here from now on.Well, what pucker that is.
You could try cutting the brake puck material with an ordinary hack saw as you may have better luck if you can hold the puck. The scroll saw blade would probably be moving too fast and as a result generate a lot of heat rather than cut into the material and the brake puck material is designed to dissipate heat. You may be able to place the puck upright on a block of wood and then use a strip of sheet metal to form a U around the puck with a small screw hole and sheet metal screw at each end to snug the sheet metal against the brake puck material so the puck is held firmly. The material will probably be pretty hard and brittle and trying to clamp it in vise jaws or by some other method may cause the material to crack. Just a suggestion.The pucks and the backing plate measure a fat 1".
You need a mill.First the caliper and rotor got bolted in to see how much room there is for brake pads and the backing plate. Had to use a snap gauge. 3/4 inch.
And something to protect your lungs.Doug it’s probably going to take a metal cutting blade to cut that puck because of the ceramic or graphite contents. Lol I responded to this two days ago and never posted it. I think 29 Chevy has a good idea. I would cut it close to what you need then sand or grind to fit.
Well, I better just leave this the puck right here---LOL! I don't want to get thrown off the site!Thanks to Doug I believe "Puck" will be a universally used word here from now on.
If the slice I was cutting off was thicker I think that would work great, Stew. It's thin enough that I think the slice would have broke off and then getting the blade to stay true would be tough to do.You could try cutting the brake puck material with an ordinary hack saw as you may have better luck if you can hold the puck. The scroll saw blade would probably be moving too fast and as a result generate a lot of heat rather than cut into the material and the brake puck material is designed to dissipate heat. You may be able to place the puck upright on a block of wood and then use a strip of sheet metal to form a U around the puck with a small screw hole and sheet metal screw at each end to snug the sheet metal against the brake puck material so the puck is held firmly. The material will probably be pretty hard and brittle and trying to clamp it in vise jaws or by some other method may cause the material to crack. Just a suggestion.
I will run right out and buy one Rick---LOL---$$$! Seriously, it would be a great tool, but no budget, experience and knowledge or room for that matter for one. I have seen smaller benchtop ones though but they looks like small hobby stuff is about all they can do.You need a mill.
It probably would have but I got them roughed in this afternoon, Jim.Doug it’s probably going to take a metal cutting blade to cut that puck because of the ceramic or graphite contents. Lol I responded to this two days ago and never posted it. I think 29 Chevy has a good idea. I would cut it close to what you need then sand or grind to fit.
I wore a respirator, Chris.And something to protect your lungs.
Your supposed to be retired. You are forever on the go. If I get to Watertown once a month that's too much.Got some running around to do first.
