The engine now has new spark plug wires and a new coil wire going from the mag down to the the distributor cap.
There is a black button on the side of the mag that you push to ground out the points and shut the engine off.
The starter switch that I'm using has a terminal that is grounded when the switch is turned off.
On the Wisconsin engines, you can connect a wire to the grounding button and run the wire to a remote switch to shut the engine off.
However, there is no way to connect a wire to the grounding button on this mag.
So .. I took the distributor cap off and cut a notch in the lower part of the distributor housing.
The wire coming from the grounding terminal on the starter switch is run thru a piece of rubber hose.
The end of this rubber hose fits into the notch and the wire is connected to the condenser wire.
There is a notch cut into the side of the rubber hose so when the distributor cap is put back on, it keeps the rubber hose held in place.
Usually when I mount a starter/generator on an engine that didn't have one originally, I have to make a special belt guard for it.
I lucked out this time because I have a guard the will fit it.
It already has several holes in the face and one mounting bracket on the top side.
The existing top mounting bracket is in the wrong place so I have to make new mounting brackets that will make use of the existing holes.
The mounting holes in the new brackets have to be out far enough so they clear the fan cover that is directly behind the grille.
The new mounting brackets are all made up.
Threaded nuts are welded to the inside of the grille so the belt guard can be easily fastened on from the outside.
Here is how it looks so far with the belt guard fastened in place.
