New project
Not much progress over the weekend on the Allis. The daughter this tractor being restored for is a nurse and she was on call this past weekend. Most of her patients are closer to my house than where she lives. She asked me if she could stay here Friday and Saturday while she is on call. I told her of course but then had to start moving painted allis parts to a different room. I also covered up the rear part of the tractor in the garage. She did not ask about what I was working on at the time so I may be able to finish this tractor without her knowing.
I did get the front main frame primed tonight, tomorrow it will be sanded. If the sanding doesn't take too long I should have it painted tomorrow night.
Most of Saturday was driving 1.5 hours one way to pick up a used camper. I plan on staying in Mt Pleasant for a few days this year for Old Threshers and didn't want to try sleeping in a pickup. Next Monday I will load up the Power King and the Minneapolis Moline and take down to exhibit for the show.
I did get the front frame bolted to the back last night.IMG_20250821_183244185.jpgIt was a pain to get the 8 bolts lined up. 4 on the sides and 4 on the inside which bolts to the 90 degree gearbox. I put the rear tires on also, my back today has reminded me what I did on the tractor yesterday.
This afternoon I worked on the new to me popup trailer. A front corner on the front storage compartment needed a wood panel replaced. It is almost ready for next week at Old Threshers.
I sandblasted most of the front axle parts today (front axle, steering tie rods, and plate the tie rods bolt on) and sprayed them with primer. I plan to sand on them tomorrow and then spray them orange tomorrow. The one tie rod from the steering box to the plate is 1/2 ground down from rubbing on something. I hope once I get it installed I can see what and why it is ground down. The tie rods are 1/2" diameter on this tractor.
Some progress today, the driveshaft from the engine to gear box is repainted. The front axle is in the tractor, i need to paint one of the axle spindles to mount both of them in the tractor. The lift cam lever is installed. I sand blasted and primed a bunch of the brackets that need installed into the frame. I hope to get them all painted tomorrow in between several other items to fix.
There may not be much progress on it for the next few days.
My plan is to go to Mt Pleasant on Wednesday and spend Thurs-Mon at Old Threshers. I plan on taking quite a few pictures while I am there. In the past it was spending just a day there and then driving back late at night. I will be a nice change to not have to rush to try to see everything.
Once I get back I need to get busy on the tractor, I want to have it done for a close by tractor show on Sept 20.
More progress yesterday, I finished up the front tires and wheels. The new tie rod end came in, finished hooking up the steering. The rod from the steering column to front looks to run on the bracket for the electric lift. I will end up replacing the whole shaft. There have been a couple of times of removing a part to be able to install a different part, joys of working on a different brand. IMG_20250902_124101773_PORTRAIT.jpgIMG_20250902_145920548_PORTRAIT.jpgI did find a run on the hood in the clear coat I need to take out before the decals go on.
Spent most of the day working on getting some panels straightened and repainted. The foot steps have been a pain due to the rust and pitting. I did get the engine installed and the drive line hooked up. And the decals for the hood are put on the hood.
The foot steps are on a long with one of the side panels. Still working on the grill, it has a lot of small dents and twists in the bottom metal. I am to the point of having to make 4 of the panels due being rusted out and parts missing.IMG_20250907_141344132_HDR.jpg
It has been a couple of busy days trying to get this tractor done. I have the easier parts done and on the tractor.IMG_20250914_114157148_PORTRAIT.jpgThe rest of the panels need some major work done to them. I will be cutting them before the rusty and missing parts and will be welding in patch panels. I have to call my metal supply store in the morning to see if they have 20 gauge steel sheet piece or scrap pieces. I still need to pull the electric clutch and exhaust off the old engine and put on the replacement engine. The hood could go on but it will be easier for wiring and remaining panels to leave off until the end.
I looked all over trying to find a dash decal but was not able to find one exactly like this one. I found one for a hydro that was close. I ended up masking it off sprayed the orange and then put clear over the orange and decal.IMG_20250914_114208745_PORTRAIT.jpgOther than the bottom right corner it turned out pretty good.
No pictures from today's doings. This morning started off on the phone trying to find some 20 gauge sheet metal to fix the missing parts on several body panels. I called the place I buy a lot of steel from and was told he would need to check and call back. After an hour of no call back I started calling metal suppliers in Des Moines. I finally found one supplier who had a 4'X10' sheet which is more than I need unless I really mess up bad. I had the car trailer hooked to my pickup so I just left it hooked on and went to Des Moines. This place is in the north part of downtown Des Moines, not the place I really wanted to go with dually pickup and trailer. I made it there and back without any issues. I completed 4 of the 7 panels as far as bending and drilling holes. I sprayed etch primer and then sprayed 2k primer on them. Tomorrow it will be checking the fit and if everything is good paint them orange. I still need to get the seat off the rear seat pan and get the seat pan repainted.
