I tried the boiled linseed oil trick on the F725. Figured it wouldn't hurt. Found I probably should have gave it a scotch-brite bath first, but it looks better.
Before:
After:
I think the 68 and the 112 with get this treatment after a bath with an old scotch-brite to remove some of the dirt!
Nothing like helping a friend out to make one feel good inside. I did that last year for a friend. He ran over a stick and jerked the wire to the clutch off. I didn't have a clutch for a vertical shaft. I used a real small drill and drilled hole down into the wire holder. Put a terminal end on a wire and run and small short screw down into the plastic block that held the wire. Talked to him the other day and he said it was still holding and running good. Talk about a Jerry Rig ! But it worked.Not my stuff, but helping another gentleman out. He's a bit older than me, wife has respiratory issues. Anyways, bought some parts and fixed a few things. I know he can't pay me right now, but I'm okay with that. He mows 1.5 acres or more and needed someone to fix a few things. Also put new cable ends on his other mower.
