Sorted, un-tangled, and installed the wire harness. I had to pull some pins out of plugs to fully untangle. Also installed 5' of new fuel line.
I did a modification on the upper steering bushing as it was allowing side-to-side and up and down movement. I added an additional nylon bushing, and washer and nuts to the mounting bolts as these loosen up often. This thing is as tight and smooth as ever now.
speaking of wiring messes, I worked on my new to me 85 D 150 today, and I cannot believe that one wiring harness on one single truck can be so hacked and discombobulated. I stripped most of it away today, put a new old stock distributor in as the wiring to the original distributor had as much electrical tape as Ace Hardware just in that 4 inches that sticks out the housing..... the big, "hot" wire off the alt changed colors 3 times in about 16".... no crimp, no wire nut even.... fusible links stripped and wire just twisted and taped....I have worked on enough old Dodges over the years, none of the other wires to the coil, distributor, alternator field and such make any sense or are anywhere close to what they used to be.... or what the factory wiring diagrams say they should be....
I gutted it, put a standalone "high performance" Jacobs ignition setup onto it taht's been collecting dust in my attic for years, to find out it was NFG..... bought it years ago for another one of my vehicles that I no longer have..…. but it was used, then.....
so I found a couple of engine wiring harnesses I had from 70s trucks, also collecting dust, these are factory harnesses/stripped the tape wrap and gutted just the electronic ignition portion of one of them, and tossed the rest of the left overs..... gonna put that on here as a "test" just to hear this engine run long enough to warm it up and test oil pressure, etc...….. got 2 wires left to connect one to a "+" hot with the key, and the other to a "+" hot in "start" or "crank" and I should have fire.
and pirated a factory electronic ignition module off my kid's 440 motorhome engine/ that I know ran when pulled, and stashed in my garage..... if he don't come for said 440 soon, it is becoming awfully tempting to drop said 440 into this truck...…
took tomorrow off work, gonna hit the local junkyard in the morning, something I usually cant do when I go to work during teh week....
my wife has a Dr appt to hopefully get released back to work (see how much good being released to work will do here given this virus BS..... )
and I took off work to go with her.... its right near noon,
also today I went out to the storage barn, was out there for the 1st time this year a few days ago/ as the kid needed my "parts" deck for the New Holland, and discovered then, that the spare roof for my Apache popup camper had fallen from where I had it stored with 2X6s within slats across the corn crib.... it had only been there 2-1/2 years.... I "had" it well strapped down, though last year I had to adjust the straps a few times over last summer.... the previous year it hadn't budged a bit, but now it was crashed to the ground..... so I went out there before messing with my truck, with my Sawzall and Coleman Pulse 1850 generator and cut up that camper top...….I had stripped out 2 of them a few years ago, sold both roofs from the part-outs, this one had come off of one that "my" roof that I sold had gone onto, it had some cracks from a limb having fallen onto it but it "was" fixable til it fell almost 10 feet...… so hopefully now mine don't get damaged...…they haven't made these campers since the mid 80s.
don't look like I'll get to actually USE that camper this year with all that is going on with this virus.....most campgrounds are closed down. I had planned on going to a few tractor shows and camping nearby while they were going on/ but tractor shows cancelled too..... blahh
